I have seen a picture with it done* with a RB20 in it. I thought there wouldnt be enough room eather but I guess if you remove the cluch fan lean the radiator back and have the intercooler on top of that with a hole in the bonit it might work?
Edited by 7yphon
https://www.sau.com.au/forums/topic/97353-vmount/#findComment-1767850
v mount is the intercooler and radiator mounted in a < formation
so the heat from the intercooler doesnt go straight into the radiator.
probably more useful on a race/track car. if you have a stack big big mess.
the idea is to pass the hot intercooler air over the top of the engine and pass the radiator air under the car instead of passing them through each other
https://www.sau.com.au/forums/topic/97353-vmount/#findComment-1787080
For those that dont know, here is a diagram.
Id think something like this is only good for a) a huge laggy turbo where you want to remove pipe length, B) drift front bar damage
I think it would fit. Ive always wanted to Vmount, pretty impractical for street though. Save your pennies
https://www.sau.com.au/forums/topic/97353-vmount/#findComment-1787487
the benefit of V mount is increase cooling system surface area
if u simple want to remove pipe length & drift front bar damage u can always mount the cooler behind the radiator support.
have a look with the ASE setup in GT autosound car
it is like:
.......__
air~> /
the have a metal sheet between the cooler and radiator to make sure cool air goes up to the cooler but not only the radiator
with a custom cooler which is thick but short in width
i think it can be done within the limit space
ASE ask 2g for the SR setup, which include aluminium radiator & FMIC, not too bad i think
Edited by Maxx
https://www.sau.com.au/forums/topic/97353-vmount/#findComment-1787643
    • Hey mate, thread dredging hahah To answer you directly, yes I had my itbs oversized and custom butterflies etc made by EFI Hardware in Sydney back around 2017-2018 if memory serves. My setup had a vast amount of other changes too though, so no direct comparisons unfortunately. i went from oem itbs, HPI manifold and internal gate hks 2835 pro S; to 49mm itbs, cnc port matched Nismo plenum, RB25 Neo lower runner adapter hand port matched, r31house v2 Takoashi MAX equal length twin scroll manifold with twin 38mm tial gates and a FP HTA3076 with 1.01ar twin scroll real hosing. feom power Fc to a link fury wired by 12volt, r32 gtr fuel tank conversion with frenchys twin 460 / surge tabk fuel hanger combo kit, 1659cc injectors, full 4 inch turbo back stainless exhaust, Z34 6 speed, Tomei 2way with 4.3 final drive and a ton of other shit. ive posted elsewhere here with complete run down, but here's a graph from its initial tune with no boost control on, 20psi gate springs only and e85.   7542AE72-DA92-4E0B-8660-B0940FEA7F24.mov
    • On sale mate, $55. Sorted. https://www.supercheapauto.com.au/p/toolpro-toolpro-torque-wrench-1-2-drive/565734.html?utm_content=paidsearch-pmax&gad_source=1&gclid=Cj0KCQjwytS-BhCKARIsAMGJyzqYEnwWmhWf6gxTST_Nz06Gd2VePgyvL7lh6PWrQtbjXTsI6TqSCLEaAuaCEALw_wcB&gclsrc=aw.ds
    • Slap it and say it ain't going no where, you'll be fine.
    • So the whole rb25de neo setup was a tiptronic setup and i swapped everything over to my rb20de neo setup and yes even the cluster of the rb25 was swapped over.
    • and I thought size mattered 😝 At this point I may either pray to the Afterpay gods and get a torque wrench or attach a water bucket to the breaker bar. I appreciate the help though 🙏🏾
