I have seen a picture with it done* with a RB20 in it. I thought there wouldnt be enough room eather but I guess if you remove the cluch fan lean the radiator back and have the intercooler on top of that with a hole in the bonit it might work?
Edited by 7yphon
https://www.sau.com.au/forums/topic/97353-vmount/#findComment-1767850
v mount is the intercooler and radiator mounted in a < formation
so the heat from the intercooler doesnt go straight into the radiator.
probably more useful on a race/track car. if you have a stack big big mess.
the idea is to pass the hot intercooler air over the top of the engine and pass the radiator air under the car instead of passing them through each other
https://www.sau.com.au/forums/topic/97353-vmount/#findComment-1787080
For those that dont know, here is a diagram.
Id think something like this is only good for a) a huge laggy turbo where you want to remove pipe length, B) drift front bar damage
I think it would fit. Ive always wanted to Vmount, pretty impractical for street though. Save your pennies
https://www.sau.com.au/forums/topic/97353-vmount/#findComment-1787487
the benefit of V mount is increase cooling system surface area
if u simple want to remove pipe length & drift front bar damage u can always mount the cooler behind the radiator support.
have a look with the ASE setup in GT autosound car
it is like:
.......__
air~> /
the have a metal sheet between the cooler and radiator to make sure cool air goes up to the cooler but not only the radiator
with a custom cooler which is thick but short in width
i think it can be done within the limit space
ASE ask 2g for the SR setup, which include aluminium radiator & FMIC, not too bad i think
Edited by Maxx
https://www.sau.com.au/forums/topic/97353-vmount/#findComment-1787643
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
