hey guys
ive just got a 32 registered that has an rb25 in it, but the wiring loom is all rb20 still. does this mean i will have to put an rb20 power fc in it or can i use an rb25 one?? also im getting a td06 20g kit on wednesday but i need to know if i can put the turbo on and safley use it without upgrading the ecu and only run like 1 bar of boost?? my current mods are 264 cams, adj cam gears, 1.2mm metal headgasket, sard fpr, dont know what type but very noisy fuel pump, fmic.
thanks......brett
https://www.sau.com.au/forums/topic/97354-rb25-in-r32/
the only diffrence that can be seen on the wiring loom side is that on the rb20 there is no vtc control and injector triggers for cyls 5 and 6 are swapped.
i just got a rb25 pfc for use on my rb20 and i plan on swapping pins for clys 5 and 6 and it should be mint.
https://www.sau.com.au/forums/topic/97354-rb25-in-r32/#findComment-1766969
