hey guys
ive just got a 32 registered that has an rb25 in it, but the wiring loom is all rb20 still. does this mean i will have to put an rb20 power fc in it or can i use an rb25 one?? also im getting a td06 20g kit on wednesday but i need to know if i can put the turbo on and safley use it without upgrading the ecu and only run like 1 bar of boost?? my current mods are 264 cams, adj cam gears, 1.2mm metal headgasket, sard fpr, dont know what type but very noisy fuel pump, fmic.
thanks......brett
https://www.sau.com.au/forums/topic/97354-rb25-in-r32/
the only diffrence that can be seen on the wiring loom side is that on the rb20 there is no vtc control and injector triggers for cyls 5 and 6 are swapped.
i just got a rb25 pfc for use on my rb20 and i plan on swapping pins for clys 5 and 6 and it should be mint.
https://www.sau.com.au/forums/topic/97354-rb25-in-r32/#findComment-1766969
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
    • Not a huge update because still waiting for some fittings for the intake. But I did corner weigh the car, its enough to make a GTR driver cry at 1163kg (race ready except no fuel)  Sorry about the terrible pics but I think they are readable With 70kg driver
