I tried searching but can not find a definent answer as most are asking about 18" rims, I am odering a set of the 17" 5Zigen fn01rc black with the polished lip i do not want to roll my fenders or have any type of issues of scrubbing. I do want the largest size i can safely put under the flares without it affecting car or driveline in any way. i was told 17 by 8 in the front 30mm offset and 17 by 9 30mm offset in the rear although with the flares on the GTR's fenders this seems kind of small to me. and there is not alot of GTR's here so the local rim shops are not very knowledgeable on these vehicles or specifications. thanks alot
https://www.sau.com.au/forums/topic/97371-rims-sizes-for-r32-gtr/
wrong section, have you tried the suspension, braking and tyres section?
there is a thread about what sizes everyone is running. As far as going larger but not affecting the driveline or the car, as soon as you go any size larger than factory you will affect the car as it was engineered originally to run its OEM stuff, some may say for the better, some may say for the worse depending on what you consider good/bad!
