Annoying problem, my R32 GTR dash and rear light fuse keeps blowing.
Pulled out the existing and swapped in a new 10A fuse, blew it straight away.
Anyone have any ideas as to what would cause this?
Would a short circuit somewhere cause this to happen?
My alarm was installed reasonably recently so there has been someone in there playing around with wires :P
Incidentally, I also noticed that for the starter signal fuse there is a 15A instead of the 10A on the diagram, and a 20A for the hazard lights instead of 10A.
Maybe replace the incorrect fuses with the correct ones.
I know this is a sh*t job but you may need to look at the connections for the alarm system. Maybe they left a wire naked and its touching the frame of the car, or something else.
Look for dodgy wiring, close up lose ends. Pretty much do an inspection of your car. Some places may be... near ECU, where your headunit is, near battery, anywhere where someone can play with and stuff up.
If those fuses that are incorrect, I would change them IMMEDIATELY. They will blow the component that its linked too.
Thanks mate.
-Arbess
> If this happened right after the alarm install, the installer could have mistaken the lamp wire as a ground. It is easily done, i accidentally did this to my mates car, while installing a stereo head unit. When the lamps are off the wire measures as ground, but when you turn the lamps on the fuse blows as wire becomes live.
> If you recently installed a head unit - read above :P
> Always replace the fuse with it's correctly marked rating. Fuses are there to protect the wirng, the last thing you want to do is to rewire you car.
Hope that helps
PS: If you are uncapable of disconnecting your all power wires to your alarm (inc ground), then go back to your installer, as them to disconnect it, replace the fuse and test the lights.
i had this problem in my 32,
found an un termintated wire behind my headunit with exposed wires, was earthing and blowing my fuses.
check back there for exposed wires plus what the other guys said
good luck
Thanks guys.
Someone also broke into the car recently and pulled out the ashtray to, i assume, get to the head unit. Maybe theyve pulled on the wires there and thats caused something.
Actually, on a reasonably hot day recently, my alarm went off twice for no reason - never done this before. This was around the same few days that the problem happened.
Bring on the pain - time to fire up that freakin' multi-meter and get my electrical tape out :D
I had the same problem but with my R33 Gts-t.
The rear light was in the "unlock" position and kept moving in and somehow caused the circuit to short and blow the fuse.
Maybe have a look at the taillights make sure its all fine?
This story ends happily..... managed to find the problem last night, one of the 40 thousand wires in behind my head unit / aircon / guages was obviously shorting somewhere, pulled that apart and tightened up all plugs and re-arranged the wires and bingo - no more popped fuse.
Whent the $%&$ broke in they must have had a play around.... never trust reservoir, melbourne.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
