Hi All,
I have been searching all night for some details on how to change a timing belt on an RB engine?
From what I gather, it is a matter of removing the radiator (for space and not a big issue whne planning on flushing the coolant at the same time) then the fan belts, covers and the timing cover...
Can anyone give me some further detail before I start or point me to a page with a detailed run-down??
Would be awesome if someone could show me where to download a workshop manual!!! :D
I have an R32 GTS-t...
THANKS in advance!!
https://www.sau.com.au/forums/topic/97407-rb20-timing-belt-replacement/
no ofesmse dude but if u cant work it out u might aswell not attemp it, ive done three of em on a r32 gtst and there not the esiest hing too do for a beginner
no ofesmse taken... I wouldnt class myself as a beginer, I have done a turbo engine conversion in my MR2 so would confidently say I am reasonably handy with a spanner! Just wanted some insite before going at it.
And thanks VERY much alexcim! Just what I was after!
Todd
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
