Now that I have brand new splitfire coils, can i revert back to 1.1mm spark plug gaps or not ?
I've read a bit of stuff on here on the forum, and some people have said that at 1.1mm the spark is a lot better on good coils than it is on 0.8mm gapped plugs. Question is, at 1.3 bar of boost with the amount of fuel i am running, will plugs at 1.1mm run fine or not.
Does anyone know?
I'm tempted to run standard gapped plugs, with maybe a colder heat range? (7 or 8's), before the car gets its final tune on saturday
Many thanks for any help
:D
well if its missing its obviously not right.
you'll soon tell.
With new coils it might be ok.
Just drop it increment at a time if you have problems. Might take a couple of hours. Just make sure ya havea few beers :D
What you mean not a good answer! Every car is different.
You dont need a dyno to check it, just 2-3 hours and a quick squirt once its warm each time :D
If its missing under boost sometimes going 1.0 to 0.8 makes all the difference
are you endorsing me drink driving ?
I think the biggest issue, is that it would need to be a squirt up the top of 3rd or in 4th gear and that = 180+
Just playin with ya. I know that this would be the easiest way of doing it. But is it worth wasting my time doing this ? As in have you or anyone seen any benefits to increasing gap ?
Maybe not better performance, but a stronger spark. If you think about it, the larger the distance between the spark plug gap thingy (whatever you wanna call it), the larger the spark will be. Larger spark = better combustion.
Its just a thought. Im just not sure whether splitfires (which i would assume are simply brand new nissan-ish coils - they wouldnt be any better spec than brand new stock coils - provie me wrong) with stock distributor will provide a big enough spark at a 1.1mm gap to withstand 1.3 bar and 3.8L of fuel/minute :D
its been proven splitfires/nissan new are virtually the same.
There was a thread with tech info about 6 months ago.
Its more the fact your using new coils vs your tired ones.
As opposed to who made em, which is better etc
Splitfires are cheaper than new ones from nissan, so thats why people use em, no other reason :D
Ok I tried a new set of Splitfires & they were "marginally" better than a 12 year old set of RB26 standard coils - I doubt if they would be any better than new oem coils. I could increase my gap from 0.6mm to 0.635mm on platinum plugs (copper plugs could run 0.8mm no problems). As to what gap you can run trial & error worked for me, you will be able to run a larger gap using copper plugs.
tommy, there is no distributor on a GTR mate. it's multi coil. :)
the bigger the spark gap you can run the better, i would think if your old coils were good then you probably wont get much gain. but if you previously closed down the gaps due to missing then you may be able to open them back up now. i would try .9 or 1.0. but i don't think you'll be able to go much more than that as 1.3 bar is pretty decent boost.
Well ive actually tried this method after fitting my Splitfires. I went back to 1.1 gap and it started to missfire, 1.0 still misfirred, and finally .85 mm is where i absolutely get no misfire running around 19psi boost, so i have found my optimum spark gap.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
