hey just a quick question.. i've got a r33 GtsT.. when i'm driving it pulls boost it won't go, it feels like it's holding back... on the boost guage it saying i'm on boost.. but yeah it doesn't go it's like it's lagging.. BUT when i turn my car off then on again, it work's normal it pulls boost then goes good... it only happens sometimes though.. any ideas??? i've checked all hte piping and vaccum it's all good... but yeah does anyone have this sort of problems??
i've got a blitz computer.... yeah it's weird when it happens, at the lights i turn the car off hten turn it back on then it drives normally
i pulled all the plugs in the engine and cleaned it.. even took out the coil packs and cleaned them too...
update.. theres' oil in the last cylinder... and spark plug was BLACK AS!! got new ones and cleaned the oil away... works BEAUTIFUL!!
5 days later... it happened again.. so i checked if there was oil in the cylinder again.. there's none so i cleaned the ends of the spark plugs. now it works good again..!! what the!! again when it did happen, i turn my car off then on again.. it worked normal again..
can't figure it out
oil in the last cylinder?
Its got bad blow by. If I were you, get it compression tested, and stop boosting in the mean time before you really wreck it.
Sounds like you are going to need a rebuild....
I have the same problem. I have a R32 GTS-t and just put a new air intake and boost controller to put it to 12 pund but still feels when it boosts not much quicker and it has alot more potential. Any idea's from anyone what this could be. The car is completely stock other than this.
why am i going through oil so quickly.. there's no leak that i can see
Oil isn't going to magically disappear. It can only be leaked out or lost in the cylinder.
Get a compression and leakdown test done, as others have said. But it looks like rebuild time.
rory_kiernan : stock r32 is 10psi? and you've gone to 12psi with not much else done... :blink:
i've got forged piston and bigger turbo...
it's running good now.. but i happens probably 2/3 times a week.. not all the time when i driving... but it's annoying when it kicks in.. cos it feels like i've lost alot of power, but the boost is there... it's set on 15psi. but when the problems kicks in it only goes to 7psi
Hey Mr Sly, i have the same problem as you at the moment, by boost laggs, but only every now and then, and im only running stock 7psi as well, with a stock ecu at the moment, any one have any idea on this one? r33 series 2 1996, it lags some times on winding up and other times around 5psi, and you can feel the pull then it kicks in, then it pulls then kicks in, its annoying the hell outa me as well, anyone think this a spark plug issue? (i havent checked them yet as been busy, but its the first thing im going to check tomorrow) just got the car back and this happened
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
