ok Taken from teknoscape
-------------------------------------------------------------------------------Name: Sasha Tour
Date: Friday 9 December 2005
Featuring: Sasha
Venue: Metro City
-------------------------------------------------------------------------------Name: A Tribute to USA House
Featuring: Tribute to USA house
Venue: Geisha
Featuring: Oldschool house & classic anthems
Venue: Sapphire
Featuring: Celebrating Destination? 2 years
Venue: Ambar
------------------------------------------------------------------------------Name: Micky Finn & MC Shabba D
Date: Saturday 10 December 2005
Featuring: Micky Finn & MC Shabba D
Venue: Heat
Date: Thursday 15 December 2005
Featuring: Shapeshifter (NZ) & Gsan (Melb)
Venue: Heat
Name: Seriously Sound System 2005
Date: Saturday 17 December 2005
Featuring: Large Local Live & DJ lineup
Venue: Hyde Park
-------------------------------------------------------------------------------Name: Gatecrasher Global Sound System
Date: Friday 16 December 2005
Featuring: M.I.K.E./Push, John O'callaghan, Dumonde, Organ Donors
Venue: Monkey Bar & The Church
-------------------------------------------------------------------------------Name: Stanton Warriors
Date: Thursday 22 December 2005
Featuring: Stanton Warriors
Venue: Heat
-------------------------------------------------------------------------------Name: Operation Blade
Date: Friday 25 December 2005
Featuring: Public Domain DJ Set
Venue: The Church
-------------------------------------------------------------------------------Name: Boxing Day Bash Carnival
Date: Monday 26 December 2005
Featuring: Pendulum
Venue: Heat
-------------------------------------------------------------------------------Name: Breakfest 2005
Featuring: Krafty Kuts, Kid Kenobi, The Herd, Soul of Man + more
Venue: Belvoir Amphitheater
-------------------------------------------------------------------------------Name: The Jigsaw NYE Massacre
Date: Saturday NYE 31 December 2005
Featuring: Perth痴 underground electronic music crews
Venue: Bakery Artrage Complex
-------------------------------------------------------------------------------Name: Calyx and Dom & Roland
Featuring: Calyx and Dom & Roland
Venue: Heat
-------------------------------------------------------------------------------Name: Sun Electric
Date: Sunday 1 NYD December 2006
Featuring: Hype, Richie Hawtin, Tall Paul + more
Venue: Belmont Park Racecourse
-------------------------------------------------------------------------------Name: Summadayze 2006
Date: Sunday 8 January 2006
Featuring: Huge international lineup
Venue: Supreme Court Gardens
-------------------------------------------------------------------------------Name: Big Day Out 2006
Date: Sunday 5 February 2006
Featuring: Large international lineup
Venue: Claremont Showgrounds
Name: Good Vibrations Festival
Date: Sunday 19 February 2006
Featuring: MAssive international lineup
Venue: Belvoir Amphitheatre
https://www.sau.com.au/forums/topic/97434-clubbing-event-guide-thread/
your stereotypical views amuse me buddy............
and agree with liz, as much as I respect sasha as a dj every time he plays live he is dissapointing his cd mixes aren't too bad though!
W00T to Stanton warriors & pendulum!!!! all the whole lineup at breakfest!!!
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
    • Is the problem that we just disconnected the line, does it need to be plugged? I’d rather not buy another master cylinder
    • Clutch is same same. Tailshaft is not. Diff will drop in. Half-shafts will not mate up (5x1 on turbo, 3x2 on NA). There is also the strong possibility that your auto NA gets its speed signal from the sensor on the diff, not the gearbag, and that will leave you without a speedo. You can do all this, you just have to do a lot more than you thought.
