ok Taken from teknoscape
-------------------------------------------------------------------------------Name: Sasha Tour
Date: Friday 9 December 2005
Featuring: Sasha
Venue: Metro City
-------------------------------------------------------------------------------Name: A Tribute to USA House
Featuring: Tribute to USA house
Venue: Geisha
Featuring: Oldschool house & classic anthems
Venue: Sapphire
Featuring: Celebrating Destination? 2 years
Venue: Ambar
------------------------------------------------------------------------------Name: Micky Finn & MC Shabba D
Date: Saturday 10 December 2005
Featuring: Micky Finn & MC Shabba D
Venue: Heat
Date: Thursday 15 December 2005
Featuring: Shapeshifter (NZ) & Gsan (Melb)
Venue: Heat
Name: Seriously Sound System 2005
Date: Saturday 17 December 2005
Featuring: Large Local Live & DJ lineup
Venue: Hyde Park
-------------------------------------------------------------------------------Name: Gatecrasher Global Sound System
Date: Friday 16 December 2005
Featuring: M.I.K.E./Push, John O'callaghan, Dumonde, Organ Donors
Venue: Monkey Bar & The Church
-------------------------------------------------------------------------------Name: Stanton Warriors
Date: Thursday 22 December 2005
Featuring: Stanton Warriors
Venue: Heat
-------------------------------------------------------------------------------Name: Operation Blade
Date: Friday 25 December 2005
Featuring: Public Domain DJ Set
Venue: The Church
-------------------------------------------------------------------------------Name: Boxing Day Bash Carnival
Date: Monday 26 December 2005
Featuring: Pendulum
Venue: Heat
-------------------------------------------------------------------------------Name: Breakfest 2005
Featuring: Krafty Kuts, Kid Kenobi, The Herd, Soul of Man + more
Venue: Belvoir Amphitheater
-------------------------------------------------------------------------------Name: The Jigsaw NYE Massacre
Date: Saturday NYE 31 December 2005
Featuring: Perth痴 underground electronic music crews
Venue: Bakery Artrage Complex
-------------------------------------------------------------------------------Name: Calyx and Dom & Roland
Featuring: Calyx and Dom & Roland
Venue: Heat
-------------------------------------------------------------------------------Name: Sun Electric
Date: Sunday 1 NYD December 2006
Featuring: Hype, Richie Hawtin, Tall Paul + more
Venue: Belmont Park Racecourse
-------------------------------------------------------------------------------Name: Summadayze 2006
Date: Sunday 8 January 2006
Featuring: Huge international lineup
Venue: Supreme Court Gardens
-------------------------------------------------------------------------------Name: Big Day Out 2006
Date: Sunday 5 February 2006
Featuring: Large international lineup
Venue: Claremont Showgrounds
Name: Good Vibrations Festival
Date: Sunday 19 February 2006
Featuring: MAssive international lineup
Venue: Belvoir Amphitheatre
https://www.sau.com.au/forums/topic/97434-clubbing-event-guide-thread/
your stereotypical views amuse me buddy............
and agree with liz, as much as I respect sasha as a dj every time he plays live he is dissapointing his cd mixes aren't too bad though!
W00T to Stanton warriors & pendulum!!!! all the whole lineup at breakfest!!!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
