Hi all
I cant get my wheel locknuts off...dont have the key, gota recheck with guy i got car from...went 2 bob janes 2day 2 c if they could get them off and no luck, then went to the distributers to see if they have spare keys to fit n still no luck. last resort will b 2 chisel them off but might scratch rims...
not sure what type, but its round on the outside and the inside is a 4 point star thing with a thin groove and bubbly (lol) ill get a pic up here tomm...
can any1 help/know any theives who've had expierence in this? lol
https://www.sau.com.au/forums/topic/97436-wheel-lock-nuts/
Except by the sounds of it he has the ones with the internal key which are harder to get off.
But as the others have said, the usual way to get them off is to mash a socket onto it and get it off that way. I had to do that on my SS cause it didn't come with the key for the lock nuts when I bought it.
https://www.sau.com.au/forums/topic/97436-wheel-lock-nuts/#findComment-1769293
Hi all
Show us a pic mate, sounds similar to the BMW wheel lock nuts..
https://www.sau.com.au/forums/topic/97436-wheel-lock-nuts/#findComment-1785028
I had the same problem last week, it took ages to get mine off.
What i did was drill straight down the centre of the stud, with a drill piece almost the same size as the stud, then chiselled as much of the lock nut away as possible, then i jacked the car up and pulled and shook on the rim, then eventually it loosened itself.
After spending days and nights on doing this, cutting up my hands and putting minor scratches on the rim trying to work out ways to get the piece of shit off, i was sitting in the car just looking through stuff and yep you guessed it.......The lock nut key was in the centre console the whole time. :) Ah well
oh yeah my lock nut is the same style as yours too.
Edited by CNFUSD
https://www.sau.com.au/forums/topic/97436-wheel-lock-nuts/#findComment-1790266
Had the same problem with mine when 1st imported....needed new tyres for blue slip.
Bash job worked ok.
Find the smallest socket that will slide over it and then go the next size down from that.
For me, once i had selected the size, went to Cash Converters and bought the same size socket for 50c and used that one instead of a good one.
Bashed it on as far as it would go, which wasn't very far, then heave ho!
https://www.sau.com.au/forums/topic/97436-wheel-lock-nuts/#findComment-1790280
vange, just get a cross-bar and hammer the closest size to the lock nut over it. It will come off in 2 seocnds flat. Or take the car to a McLeods or whatever and get them to do it - they do it all the time.
https://www.sau.com.au/forums/topic/97436-wheel-lock-nuts/#findComment-1792681
that sucks CNFUSD, all that work 4 nothing....u think urs would fit?
I dont think the chances of mine fitting would be to good, so id say that you would be better off doing what i had to do, or if you can still drive take it to a tyre place, i didnt have that option cos it went flat on a saturday night, so i had to get the thing towed hm.
Good luck
https://www.sau.com.au/forums/topic/97436-wheel-lock-nuts/#findComment-1793952
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
