Hi all, getting closer to start spending stupid amounts of money on my car and am starting to wonder about turbos. I've been told all sorts of different things in regards to which turbo I should use. I'm starting to think the T04Z would be a lot of fun as searching through the forums itseems it has only been bolted onto GTRs.
Does anyone have any suggestions ideas regarding one of these turbos being fitted to a 34 ?? the engine will have all the supporting mods done at the same time as the turbo.
I'm not chasing any specific power figure or have any set purpose for the car.
Cheers
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/
  • Replies 54
Hey mate, I just realised that was you leaving Bel on saturday when I arrived (with my dog). I was searching my head for your plates but couldn't remember who you were.
The T04Z is a pretty bloody big turbo. You would need to do some farily major internal work to raise the rev limit to make any use of it at all.
I seriously think you are better off deciding on a power figure, maybe go for a ride in some powerful cars to decide, and then pick your parts to suit that.
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1767534
Hi mate, I didn't see your car anywhere, which is probably why I didn't say hi :)
I was out on saturday night with an R33 with roughly 320rwkw and it really looks like a lot of fun :)
what would be needed/recommended for 270-300rwkw ?? I would basically like to keep the engine internally stock unless something happens/is needed.
Edited by Binky1970
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1767553
A T04Z is too big (overkill) for 270-300rwkw.
I'd look along the lines of a GT3040 or similar, plenty of guys on the forums with setups using that turbo in your desired power range. I also wouldn't push it any harder than that - as the bottom end is only limited in that sort of power application.
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1767607
Ahhh, ok. I had originally been told a GT-RS would be the ideal turbo for what I was looking for, but I keep getting people telling me different things.
For the second round of mods I was looking at turbo, cams, fuel system, coils, oil cooler.
I already have FMIC, PFC, filter, full 3" zorst with hi flow cat, EBC.
What sort of power would be possible with a GT-RS and those mods ??
Edited by Binky1970
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1767721
As Morgs said, a T04Z is way to big for 270-300rwkw.
Something like a GT-RS would be perfect in a low mount setup, or there are a couple of high mount options you could choose (ie GT3040, Trust TD06 etc) but these would up the costs by the time you buy a manifold, wastegate and the required fittings.
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1767761
GT30 lowmount.
Stock head
270rwkw @ 17psi
Do a search. 270-300rwkw is an extremely common question and many people will have asked, and had answered all your questions that you havent even thought of yet.
Its approx 10-12k adventure if you plan on having it remotely reliable
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1769351
yes and no. either the GTRS or GT2835Pro will be fine on a stock motor provided its healthy. My unopened (not even a head gasket!) 1993 rb25 was well used and abused on track and strip, running over 260rwkw and still has near perfect compression, so if your tune is good your stock motor might last indefinitly especially if its a street car.
the GTRS will probably be a bit shy of your target, you might see 250rwkw with a good setup. (has anyone seen more than this yet from a gtrs?)
im making just over 280rwkw (at 17psi) with small cams and a cheap cooler. IMO if your gonna chase 300rwkw and over, your best going gtr of some sort.
cheers
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1770154
start by upgrading fuel pump and injectors to get the 250rwkw i mentioned above (may have to lose the "highflow" cat, as its probably not that highflow). might be possible to stretch the stock injectors with a FPR, as its rumoured that they actually flow around the same as r33 ones?!
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1770166
I think the low mount GT30 is the best idea - good response, cheap to fit (low mount, internally gated), and plenty capable.
:P
You can get them relatively easy too...
That said, a 3040 should enable you to run more power in the future if you build the motor etc... but will be a little more laggy and more expensive for the time being.
Edited by TommO
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1770608
Hey Binky1970....were you at the recent circuit club wakefield day ?
I think I saw your car parked outside the timing building.
Anyways your pretty much at the same stage as I am...except it looks like I might be spending the money on the exterior first cause of some pricks keying it.
However Ive been doing research on the turbos for my 34 for awhile and if you want good response and around 270 -300rwkw id say HKS 2835 Pro S hands down. along with some injectors, thicker metal head gasket and some cams and port and polished head.
If you get the one that comes in kit form than you MAY find it hard to reach those figures as it only comes in the 0.63 housing.....a custom manifold made to suit a 0.86 housing might get you what your after.
You dont HAVE to but for a high mount setup id prefer to change the plenum first to a forward feed style.
Goodluck trying to find a "bolt on" one for the neo....im still searching.
On the topic of high mounts...im very tempted to go for a 3037s highmounted with a external gate. This should definetly get you the power you want and will also look awesome in the engine bay !! hehe yes im a ricer ! :)
If I cant find a bolt on style aftermarket plenum that im happy with than ill most probably go for a 2835 Pro S or maybe even a 2835R with an external gate again this will require some more work with manifolds etc.
Or depending on budget might look into getting either a Blitz K5-660R or an Apexi RX6B......just to be different. everyone seems to go for garrett/HKS or trust.
hope this helps....let me know how you go.
T04Z......hehehe would be awesome but you`d get beaten by most cars out there with more responsive turbos...cause even when you do finally get boost youll be going sideways and not forward ! :)
Edited by shonen
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1771411
Yeah I was down at wakefield for the track day. I was driving a mate down there so he could take photos of another mate. I'd like to take my 34 for a few laps but i'm pretty sure the stock turbo would spit the impeller really quickly :D
I was looking at the Trust turbo for the same reason of just being different.
won't the Greddy 33 plenum fit the NEO ??
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1771808
nope the 33 greddy plenum doesnt fit the neo......you either need an adapter plate which is almost impossible to get a hold of or drill new threads in the cylinder head to make the 33 one fit. The second option is not one I would like to take....so im still searching for that elusive adapter plate.
the trust TD05-18G you mentioned wont make the power your after.......need at least a TD06-20G I reckon.
hahha your car will be right if you just run 0.6 bar of boost ie stock boost. I have been to wakie many times with my car and have never had a problem. But I have heard of reports of 34s running stock turbo and running 0.8 bar or more and blowing up their turbos.
I was there on thursday but I was with the pro concept civic....my car was out of action for track duties...blown turbo to dump gasket.
Edited by shonen
https://www.sau.com.au/forums/topic/97443-t04z-on-a-34gt-t/#findComment-1772355
    • Long time no see, I haven't posted since 14 years ago... To cut to the chase, R32 GTR. dead stock. Split wastegate hose = stock turbos were overboosting = front turbo's exhaust wheel has shattered. Have done a compression test following this and the results are (dry, cold) - 120 / 60 / 75 / 110 / 150 / 150. Haven't bothered with a wet test or leakdown test. The results definitely support front turbo failure (on 1-3) however the low compression on #4 is concerning too. Can anyone share their experience of when their turbine wheel shattered and damaged their motor - and what work needed to be done afterwards? Pistons? Rings? Valves? Throwing in the bin or salvageable? Motor is 100% stock. Will be getting it looked at further soon - I don't have a borescope and head hasn't come off (yet).
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
