I've seen over 300rwkw from a stock bottom end R33 with GT-RS and cams.  There is a thread on it somewhere here.
can anyone link to this thread? i cant find it via search. OVER 300rwkw from a GTRS is a very big ask, i will believe it only when i see the dyno graph! Thats over 500hp at the engine from a 400ps rated turbo. even with a conservative rating thats still a big ask!
  • Replies 54
http://image-cache.skylinesaustralia.com/f...-1126786146.jpg
well i quess you have your dyno reasults and it was in fast fours as i said But with people on the forum only making 360-390rwkws with two on a gtr :(
Edited by blk180
So if I go to the GT-RS (more than likely) what should be considered while the turbo is being done ??
GT-RS turbo
Dump pipe (HKS Extension pipe)
Tomei Poncams (264s?)
Fuel Pump
Injectors (Blitz seem to be the only direct fits i can find)
Headgasket (Tomei 1.6/1.8mm)
Oil Cooler
Splitfire Coils
adjustable cam gears ?
Z32 afm ?
can't seem to think of anything else.
Edited by Binky1970
nope the 33 greddy plenum doesnt fit the neo......you either need an adapter plate which is almost impossible to get a hold of or drill new threads in the cylinder head to make the 33 one fit. The second option is not one I would like to take....so im still searching for that elusive adapter plate.
Correct on the Greddy plenum... I also investigated this and found the same information. The stock plenum works fine though up to about 600hp, it just doesn't look as cool as the greddy plenum :lol:
hahha your car will be right if you just run 0.6 bar of boost ie stock boost. I have been to wakie many times with my car and have never had a problem. But I have heard of reports of 34s running stock turbo and running 0.8 bar or more and blowing up their turbos.
lol then i must have some kind of freak turbo because mine sees 0.9 Bar every time i drive it, and it's been fine at that boost level for over 18months, with a few track days too B) New HKS GT series turbo coming soon though :D
O/T guys but you could rate the GT-RS (esentially badge engineered Garrett GT2871R 52T with T3 flange and Skyline specific dump pattern) as ~ 420Hp compressor and 330 Hp turbine side . That exhaust housing is only .64ARR so 300Kw of exhaust flow ?
That GCG Hi Flow would be very cost effective particularly as you already have the R34 Neo type exhaust housing , one out one in and no orphan bits needed . Will look dead stock and is rebuildable . How easy is that .
Cheers A .
Edited by discopotato03
you going for an internal gate or an external ?
I think the Plazmaman one might fit the 34s.....as it uses the standard runners.
Just need to find out of the runners are the same on 34s are they are for 33s.
You'll need to find out if its chrome coated too... after all A/M plenums are more cosmetic than performance based unless your making something over what a stock motor is going to handle
:D
480cc will be pushing it @ 300rwkw.
Get the Nismo 550. Bolt it and gives you the required head room
stock boost on a 34gtt is 0.8-0.9 bar. provided it isnt pinging :D
I was lead to beleive its 0.6 or 0.7 ?
I turn it up to 0.9 when I feel like giving it a hit...
R31Nismoid: AFAIK nismo dont have 550cc for 34s.
I think next step up will be 740cc which is a little bit overkill.
Stock boost is 0.5 bar.
I have also never heard of 550cc Nismo injectors for the R34.
Not that I've done the calculations but I think 480's might be a bit small for 300rwkw too.
Are you sure you've got the right GT-RS there discopotato? That doesn't seem right based on what we are seeing on the dynos.
Cheers  A .
I thought the 0.64 turbine was the GTR one and the GTST was 0.8'ish.
Based on what I have seen HKS compressors seem capable of around 10% more than their rated capacity. So my feeling would be that the 420 bhp tops out around 460 bhp. That's 285 rwkw (using the usual 2wd Skylines losses of ~60 kw). It wouldn't take much of a "happy" dyno to read 300 rwkw.
:) cheers :D
:) cheers :D
Especially as the 300rwkw was on a dynojet dyno.
In "Ls1-land" we find the dynojet figures to be generally around 10-15% higher than dyno dynamics figures for the same mods.
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
