  Abo Bob said:
I've seen over 300rwkw from a stock bottom end R33 with GT-RS and cams.  There is a thread on it somewhere here.
can anyone link to this thread? i cant find it via search. OVER 300rwkw from a GTRS is a very big ask, i will believe it only when i see the dyno graph! Thats over 500hp at the engine from a 400ps rated turbo. even with a conservative rating thats still a big ask!
  • Replies 54
http://image-cache.skylinesaustralia.com/f...-1126786146.jpg
well i quess you have your dyno reasults and it was in fast fours as i said But with people on the forum only making 360-390rwkws with two on a gtr :(
Edited by blk180
So if I go to the GT-RS (more than likely) what should be considered while the turbo is being done ??
GT-RS turbo
Dump pipe (HKS Extension pipe)
Tomei Poncams (264s?)
Fuel Pump
Injectors (Blitz seem to be the only direct fits i can find)
Headgasket (Tomei 1.6/1.8mm)
Oil Cooler
Splitfire Coils
adjustable cam gears ?
Z32 afm ?
can't seem to think of anything else.
Edited by Binky1970
  shonen said:
nope the 33 greddy plenum doesnt fit the neo......you either need an adapter plate which is almost impossible to get a hold of or drill new threads in the cylinder head to make the 33 one fit. The second option is not one I would like to take....so im still searching for that elusive adapter plate.
Correct on the Greddy plenum... I also investigated this and found the same information. The stock plenum works fine though up to about 600hp, it just doesn't look as cool as the greddy plenum :lol:
  shonen said:
hahha your car will be right if you just run 0.6 bar of boost ie stock boost. I have been to wakie many times with my car and have never had a problem. But I have heard of reports of 34s running stock turbo and running 0.8 bar or more and blowing up their turbos.
lol then i must have some kind of freak turbo because mine sees 0.9 Bar every time i drive it, and it's been fine at that boost level for over 18months, with a few track days too B) New HKS GT series turbo coming soon though :D
O/T guys but you could rate the GT-RS (esentially badge engineered Garrett GT2871R 52T with T3 flange and Skyline specific dump pattern) as ~ 420Hp compressor and 330 Hp turbine side . That exhaust housing is only .64ARR so 300Kw of exhaust flow ?
That GCG Hi Flow would be very cost effective particularly as you already have the R34 Neo type exhaust housing , one out one in and no orphan bits needed . Will look dead stock and is rebuildable . How easy is that .
Cheers A .
Edited by discopotato03
you going for an internal gate or an external ?
I think the Plazmaman one might fit the 34s.....as it uses the standard runners.
Just need to find out of the runners are the same on 34s are they are for 33s.
You'll need to find out if its chrome coated too... after all A/M plenums are more cosmetic than performance based unless your making something over what a stock motor is going to handle
:D
480cc will be pushing it @ 300rwkw.
Get the Nismo 550. Bolt it and gives you the required head room
  T04GTR said:
stock boost on a 34gtt is 0.8-0.9 bar. provided it isnt pinging :D
I was lead to beleive its 0.6 or 0.7 ?
I turn it up to 0.9 when I feel like giving it a hit...
R31Nismoid: AFAIK nismo dont have 550cc for 34s.
I think next step up will be 740cc which is a little bit overkill.
Stock boost is 0.5 bar.
I have also never heard of 550cc Nismo injectors for the R34.
Not that I've done the calculations but I think 480's might be a bit small for 300rwkw too.
Are you sure you've got the right GT-RS there discopotato? That doesn't seem right based on what we are seeing on the dynos.
Cheers  A .
I thought the 0.64 turbine was the GTR one and the GTST was 0.8'ish.
Based on what I have seen HKS compressors seem capable of around 10% more than their rated capacity. So my feeling would be that the 420 bhp tops out around 460 bhp. That's 285 rwkw (using the usual 2wd Skylines losses of ~60 kw). It wouldn't take much of a "happy" dyno to read 300 rwkw.
:) cheers :D
:) cheers :D
Especially as the 300rwkw was on a dynojet dyno.
In "Ls1-land" we find the dynojet figures to be generally around 10-15% higher than dyno dynamics figures for the same mods.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
