  • 3 weeks later...
Do you actually need a cannon? i'm not that well educated on the subject, but i thought cannons were for turbo cars, NA versions needed something more substantial to create sufficient backpressure to run well (or something like that). Anyone feel free to tell me otherwise, i'm in the market for a new exhaust system and don't want a loud, droning note.
if your exhaust is 2.5" factory its probly crush bent.
somthing that could make your guys lifes easyer with r33s you could buy the turbo guys factory exhuast as they are 2.5" mandrel bent from the factory. i have one on my car even tho its rb20e.. but that will be gone for a rb30de soon. lol.
yeah N/As need some back pressure as it helps the scavanging effect. a muffler like a flowmaster one would probly sound good. i will replace my stock rear muffler when i get the new motor put in as this one is a little rattly and doesn't make much sound. plus i don't get the typical skyline backfire :huh:
correct - stock exhaust was/is crush bent. will be interested to hear about your experience building the RB30DE
well so far i have most of everything that i will need to get it up and running. you can see the difference in rod lengths of rb30 and rb25. i just need to get the bottom end rebuilt and the head put on then i can finish the rest. it has a braded hose running from the head to just next to the oil filter. i will post some pics up when i have the basic block assembled.
i am only missing 3 major components, gearbox, clutch and computer plus ill need custom extractors.
it should be good when its all up and running. ill use a plug in GTS link once it is run in. hopfully completed and in car by end of january to mid febuary :D
  • 4 weeks later...
Are you sure stock piping is 2.25"? I measured mine this morning for the new muffler and it came out to be a fraction less than 2" - the guy who imported it told me it was "dead stock". Why would anyone put on an exhaust which was smaller than stock (and mild steel to boot)?
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
