Hey,
Have found a R32 GTR V spec (not a V Spec 2). Can anyone tell me what differences there are between the first version v spec, a normal 32 GTR and the v spec 2???
Does anyone know how to tell if it is a genuine V spec??? i.e Chassis numbers etc???
Any help much appreciated.
Peter.
https://www.sau.com.au/forums/topic/97485-32-gtr-v-spec-1-differences/
V Spec's had 17" wheels and Brembo brakes with solid rotors..... that's the biggest give away. If the car you found has these but your not sure about it's legitemacy, check the chassis number with Nissan.
STD R32 GTR's had 16" wheels with Nissan Calipers and Cross Drilled Rotors.
i have nismo/nissan book at home that lists all the chassis numbers for regular 32 GTR, 32 v spec and v spec II. it also shows the colours available, and what spec levels etc. so if you tell me the chassis number i can confirm it.
I beliveve that only the V-spec 2's came with the Brembos, this one does not have them. I dont have the full chassis number but this is the model number that he has placed on the advert. KBNR32RXFSAA. I think some of these letters would refer to paint codes etc. The car is white.
As far as i know all standard R32 GTR's have a finned diff all V-spec and V-spec II have a flat diff cover so the opposite of the R33's. Best way to tell is the model code V-spec II have KBNR32BFS8 AA where a V-spec does not have the 8 on the end and normal GTR's do not have the S or the 8 on the end so yours sounds like a genuine v-spec. all v-spec and v-spec II 's came with brembos from the r33 GTR's the only difference that i can remember is the tyres 225 for the v-spec and 245 for the v-spec II
Cool thanks, Okay so this car is missing the brembo's, The owner tells me that this one is a 92' and brembo equipped versions did not come in until later, is this plausible or just an excuse to hide the fact that somome has removed the Brembos????
yes, it just sounds like a 1992 GTR. Benm, i'll bring the book into work tomorrow and scan some pages or something. or you can read it in person whilst giving me the CD with the last V8 SC round on it :P
Thanks guys, me thinks that this guy is playing games, telling people that it is a v-spec in hope that it will increase his chances of a sale. He has dropped his price $7000. Maybe he has realised that people arent so easily fooled.
  • 2 years later...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
