Hi,
My brake pads are on their way out and after doing a number of searches wasn't able to find any substantial information.
I have next to no background knowledge on them so any information would be greatly appreciated.
The car is almost entirely used on the street with standard brake setup at the moment.
TIA Jonathan
https://www.sau.com.au/forums/topic/97496-which-brake-pads-for-street-r32-gtr/
was looking at that myself recently. apparently Race Brakes, Bendix, or maybe EBC are the brands ppl are buying. I'm getting some EBC Greenstuff pads tomorrow, having just read (after the fact) that they aren't the best, but it seems there's always someone whose got a good or bad opinion of every pad. Apparently Bendix are cheap and good. Just search.. "bendix racebrakes" and make sure u include results from the "any time period" (as opposed to the last 30 days default). Hopefully ur in a position u can pick and choose and shop around.
Jonathan you can have my recently removed set of Hitachi's to try if you want? They have plenty of meat left. Only reason I changed them is to fit some RB74's I found. Changing pads is a piece of cake too if you're concerned.
edit: typo
Edited by cowie165
  • 6 years later...
Just did a search, and brought up this old thread. I also need some Pads for my R32 GTR. Street use Only. I need some that don't put out so much brake dust, as my current ones do alot. They are Green in colour. Less is better. What's out there that's not too expensive?
Another member qouted these back in 2009.
"QFM HPX. Good for 550 degrees, or the about the same performance as Bendix Ultimate, but the HPX's are virtually dust free, unlike most pads at this level of performance. They also have excellent pedal feel, and will be more than enough for a street car."
Anyone else had experience with these?
Id go with bendix ultimates. Ive just changed to them from trw pads and they stop heaps better, although can be a little squeeky under real light braking or heavy braking but
that might go away a bit as ive only had them in for about a week. They are about as dusty as the trw's but the dust is grey and a little less noticeable compared to the ugly
brown dust that the trw's throw out.
Il probably be the first one to advise you against the bendix ultimates.
Can get very very squeeky under light braking and after not too long most people mistaken my wheels as being powder coated black from the amount of brake dust.
On the upside though these are only really cosmetic factors you could say and the pad itself does a fairly good job at what its designed to do - make you stop ! Personally I wouldnt buy them again and would rather try out something different on the market
Hmm, ive heard mixed reviews about the Bendix. But I've heard some really good stuff about the QFM A1RM's $119 per pair, no noise, no dust. They are Australian made too.<BR> <BR>http://www.ebay.com.au/itm/370569065874?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 http://www.ebay.com.au/itm/370569065878?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Edited by 91BNR32
Im using remsa pads atm, great for hard street use. Theyre suppose to be better than the hpx's but not quite as good as the a1rm's. Not too dusty and not noisy plus great bite. Dont rate bendix ultimates at all, fade heaps, dusty as hell and they sound like nails on a chalkboard
^ This man knows.
If you're not doing track work, then don't get the A1RM. If you are, then unfortunately noise is just part and parcel of pads that are capable of that level of performance. I wouldn't say they're a noisy pad, because in 99% of cars they're not, but with opposed pistons calipers (like the Sumitomo and Brembo found on Skylines), noise is occasionally an issue.
Of the 15 or so brands of pads that we do (including EBC and Bendix), our pick for high performance street use would be QFM HPX if dust is of concern, or Remsa if you don't mind trading off a little dust for extra performance. Remsa is what we typically supply to high end Euro sports cars like Porsche/Ferrari/Lambo etc.
EBC's are HIDEOUSLY overpriced, and not that crash hot. They work ok in Europe where their rotors are softer and the ambient temperatures are lower, but over here there's much better pads on the market.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
