I had a powerfc, avcr and fmic installed, plugs changed from iridium’s to coppers and my car tuned. r34 GTT btw.
Before I had this done I had misfiring problems at 4-5k rpm, after it was done there was no misfiring.
This was about one and a half months ago, and now I have started getting the misfiring again.
Have the plugs worn out so quickly?
I can’t think what else it would be.
https://www.sau.com.au/forums/topic/97590-how-quick-do-plugs-wear-out/
What were the plugs gapped to?
best all round gap is 0.8mm. If its not your plugs it will in most cases be your coil packs. I know this happens often on series 1's (the missfire).
Spook's skyline i would gap them to 0.8mm but if you have something different and its running fine i would not bother chaging it.
im not sure what my problem is
car shudders (feels like a miss) when fully on it changing into second, its hte only time it does it;
im about to get the car serviced, so was just oging to my mechanic to check teh gaps;
any new info on this thread? did u fix the problem...
i just got my 100k service on my r32 its got exhaust, pod, fmic and 13psi and i just had iridium plugs put in...
it has a very slight miss on idle and is now misfiring and popping in 2nd gear when i boot it.
i immediatly thought it was the plug gap and havent checked it yet. so if someone has done this and it fixed it lemme know!
cheers
i ran my car on 1.1mm iridiums at pretty much the same boost
used to get a slight miss, which got a bit worse when it got colder
i taped up the coil packs so they wouldn't arc, and it seemed to work
eventually i just replaced the coil packs with brand new splitfires, worked a treat after that
even ran ok pulling ~1bar at 1.1mm, though i'm planning on running more with my new turbo and shit
i have a series 1 r33 and i had a slight miss after 4500-5000rpm through the gears and under full load.
i fitted some iridium plugs gapped to 0.8mm and it runs perfect now.
car only has a cat back exhaust and a pod. stock boost....
I am changing my plugs tommorrow, will let you know if it fixes it.
The missfire is really bad. Goes from 4-5k all the way to redline.
This started within a week of taking my car to a workshop to have my dump pipe wrapped in heatape. They forgot to do it when I had all the original work done.
But they messed me around and were very rude and to top it off didnt even do the heat tape properly. They only did the bottom half of the dump which is not were you even need it.
I am paranoid thinking they did something to make my car missfire... Is this possible?
I just dont understand how I could have problems only 1 and a half months after new plugs were installed and the car was tuned.
Edited by noise
I run NGK 6 coppers and leave them in for ~30,000km's.
The plugs that come out at 30,000km's work just as well as the new plugs.
$16.80 for 6 from motor traders, you can't go wrong.
I've had problems with copper plugs that have done 50,000km's. No major problems, starting became difficult.
Edited by Cubes
Put in a new tank of fuel and all missfire problems seemed to have stopped????
new set of plugs are gapped at 0.8 and sitting on my kitchen table, they never got installed.
I just noticed splitfire coil packs have dropped in price on nengun, so might wait and see how it goes and get some if it keeps playing up.
I just hope it stays good. woooooo
Edited by noise
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
