PRICE DROP
$210
Item: r34 GTT 5zigen miracle fireball catback exhaust
Link to 5zigen website
Item Condition: Good
Reason for Selling: missus is complaining bout the noise and i found one another one for sale
Price and Payment Conditions: $210 PRICE DROP!~!!! ono
Extra Info:
it is VERY light and weighs next to nothing
low bassy grumble on idle and absolutely screams up in the higher revs
*WARNING - it is loud but does not drone
3'' piping and a 3.5'' angle cut cannon tip
was originally of a r34 GTR but it was modded to fit a GTT
Contact Details:
Prefer sydney buyer so you can hear it and see for yo
Contact via pm or post below
Edited by mr_greddy
edit:
i asked a friend who confirmed with someone (nightcrawler) who fitted a 2dr exhaust to a 4dr , no mods needed .. its just a bit shorter at the tip (4cm)
but seeing my exhaust extends out a bit, it should look just right
price is fairly low already for a nice jdm item =)
Edited by mr_greddy
yes
my friend has modified an exhaust from a r33 to a gtt
cost him around $100 and modified 10cm of piping
i would assume its the same vice versa and might be cheaper depending where you go.. my friend went to a "respected" workshop to get his work done
Hey mate still interested, any pics of the underside of the muffler, also a pic of it on the car. The one you sent doesn't really show it. Also clearer pics of where it has been modified eg the welding on the brown section of the pipe. It is Stainless steel yeah?
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
