PRICE DROP
$210
Item: r34 GTT 5zigen miracle fireball catback exhaust
Link to 5zigen website
Item Condition: Good
Reason for Selling: missus is complaining bout the noise and i found one another one for sale
Price and Payment Conditions: $210 PRICE DROP!~!!! ono
Extra Info:
it is VERY light and weighs next to nothing
low bassy grumble on idle and absolutely screams up in the higher revs
*WARNING - it is loud but does not drone
3'' piping and a 3.5'' angle cut cannon tip
was originally of a r34 GTR but it was modded to fit a GTT
Contact Details:
Prefer sydney buyer so you can hear it and see for yo
Contact via pm or post below
Edited by mr_greddy
edit:
i asked a friend who confirmed with someone (nightcrawler) who fitted a 2dr exhaust to a 4dr , no mods needed .. its just a bit shorter at the tip (4cm)
but seeing my exhaust extends out a bit, it should look just right
price is fairly low already for a nice jdm item =)
Edited by mr_greddy
yes
my friend has modified an exhaust from a r33 to a gtt
cost him around $100 and modified 10cm of piping
i would assume its the same vice versa and might be cheaper depending where you go.. my friend went to a "respected" workshop to get his work done
Hey mate still interested, any pics of the underside of the muffler, also a pic of it on the car. The one you sent doesn't really show it. Also clearer pics of where it has been modified eg the welding on the brown section of the pipe. It is Stainless steel yeah?
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
