  • Replies 50
never had one break, or heard of one breaking but i've seen heaps with the dodgy speedo needle boogie at low speed (even my GTR does it up to about 20kmh).
i would say yes, something else is wrong. was the second one you broke bought brand new? if not i'd suggest buying a new one this time around.
i bought it second hand
when i fitted the second one, where it goes into the gearbox, the cable part looked to be on too sharp an angle.
is there meant to be anything else or just the cable straight into the box
The problem with speedo cables is having bends where the cable lies which are too sharp - it causes whip (which after a while will present itself as the needle 'boogie' as described above up to 20km/h. BTW It will gradually get worse until the cable snaps.)
There are a few ways to rectify this:
1. Rerun your cable with minimal bends and the largest radius on those bends which you need.
2. Remove the inner cable and grease it up as much as you can. Use bearing grease and run the inner through the grease packing as much as possible onto the cable / into the inside of the outer cable as you can. This will act not only to lubricate but it will also dampen the cable whip which should reduce the amount of funky needle bounce at low speed.
3. Find your nearest cable manufacturer (ie Gaugeworks in SA) who can build you a new inner cable - should cost approx $70 if you remove and install your speedo cable or around $140 if you give them the car - drive in drive out.
Good luck with you cables peoples!!!!!
Is there a how to guide on changing speedo calbes in R32's? If not, those that have done it care to share any tricks to changing the cable, how to get to the back of the speedo, etc
:D cheers :)
Edited by Sydneykid
Yer, dont remove the outer casing, just take out the dash cluster and the end from the gearbox.
You can slide the new inner (made from Gaugeworks (who even make it with a metal end where it goes into the cluster so it doesnt snap)) with new grease.
I dont see the need to remove the whole lot if its the inner thats snapped....
Edited by Bl4cK32
I've had one snap. I grabbed a very good condition second hand one and grabbed a can of motorcycle chain lube and sprayed as much as I possibly could down the guts, repeating this every minute or so until evidence of the lube started coming out the other end. Installed it and so far so good ( 3 years on ).
BTW. I used motorcycle chain lube cause it sprays in as a liquid and penetrates well then solidifies somewhat to a grease consistency.
  • 1 year later...
  • 1 month later...
Lay on the ground drivers side, look along the body of the gearbox, it'll jump out at you.
You can repair the end, strap and glue the hard sheath and replace it back onto the cable if you want a repair, not a replace.
Need a step by step for the repair just ask, mine snapped the other week and a successful repair still holding.
James.
yep mine sat at zero about 3 months ago. it was the plastic needle casing thing that sits at the end of the cable. it had to cracks down the side which meant that the needle that is held this plastic casing wasnt transferring the rotation to the dial.
what i did to cure this, and today it works ok, but still has boogie, was i pulled the casing and needle out, becareful not to lose the spring, got some electrical "heat shrink" which you can buy at.... electrical shops... and cut about 1/4 - 1/2 inch, place that over the casing with the needle in it, then heat it up and it will shrink onto the casing holding it into place. thats my cheap fix, cost me 1 hour and no $$$.
some interesting facts: nissan sells new ones at around 100 i think (for gtst). gtr cables might be different in design to gtst, and it would cost you less to put it in yourself.
Last I hear they were $110 from nissan. Probably the cheapest GTR part in the catalogue.
I basically did the same as arbess, but put a dab of devcon metal epoxy on the end bit where the cable end sits into the plastic sleeve, as an extra precaution. After fixing the sleeve, it just clipped back on the end of the cable anyway.
James.
Edited by heller44
Ok. I had some time today (hurrah for "Canberra Day") and managed to get the gauge cluster out (which was a bitch). Unsurprisingly the white needle end behind the speedo has snapped off. (Worse news is that it snapped below the needle end itself, so I can't easily repair it).
How do I remove the inner? Just pull the inner cable from the gearbox end with some pliers? I doesn't exactly feel like it wants to budge.
Edit: So I tried pulling the inner cable and it doesn't seem like its small enough to pass through the larger black cable, so the black cable started to pull out. Is there some trick I'm missing here?
the plastic rectangular jig is broken in the cable. I am resorting to replacing the cable and the plastic jig in one go. Hopefully this should see the speedo come back to life.
I am astounded by the amount of people who are having the same problem.
I will take happysnaps of the process for those who want to do it themselves.
Edited by Tofu
I broke two for some reason it seems to be a 3 piece speedo cable. both spilt where the plastic joins the steal cable beacuse i had it apart anyway i just super glued the plastic peice back onto the metal lol and havnt had any problems.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
