  • Replies 50
$35 in Canberra? Where Lucien????
My cable has been rattling since I've owned the car, and I'm keen to get it replaced...
Not in Canberra, but GaugeWorks in SA. Its $35 to have the inner cable replaced, and a few dollars more to replace the connectors at each end. All up GaugeWorks charged me $58 (inc postage). I sent it on Tuesday and had it back on Friday.
I've just finished installing it, so if you have any questions, fire away.
Fair enough. Its a pretty "simple" job in terms of skills. I must confess I did it the dangerous way with the tyre jack that comes in the boot (highly not recommended if you value your life). Basically goes a little like this:
1. Remove bottom dash. Remove the surrounds from the steering column. Remove the dash surround. Remove the gauge cluster.
2. Disconnect the speedo cable from the dash (it clips in).
3. Disconnect the speedo cable from the gearbox.
4. From underneath the car, look up at the firewall where the speedo cable passes through. There is a rubber triangle with three bolts (10mm; two at the bottom, one at the top). Remove the bolts and pull out the triangle.
5. The speedo cable has a number of plastic cylinders on it that hook on to points of the underbody. Unclip them. You need to feed the speedo cable towards the rear of the car until the end that connects to the speedo is out of the cabin.
6. You will then need to feed the cable towards the front of the car to actually get it out as the rubber triangle is too big to pass all the obstructions when feeding it to the rear of the car.
As I said, pretty simple. All you really need is a jack, a ratchet with 10mm socket, an adjustable wrench (or a spanner of some unknown size) and a phillips head screwdriver.. and some patience :P
May be a dumb question but my mates speedo stopped working then about 10 mins later his power steering cut out and would stay off until the car was switched off, then it would work again for a little while.... Tonight my speedo stopped working then about 10 mins later my power steering did the same thing, is this a common thing too, or just a very weird coincidence?????
It is related.
Where the cable goes into the rear of the speedo module, there is a pickup for ground speed.
No cable rotate : No ground speed signal sent to control modules.
The ~10 mins is the failsafe timeout.
James.
Made my day too!! :wub:
Ive been driving around with no cable for ages. Took it out cos I buggered it when taking out the dash. Hopefully when I put a new one in, all will be good :stupid:
So sick of turning the car off while driving and then clutching it back on LOL. Every ten minutes.
  • 1 month later...
sorry to bring up an old thread, but i just wanted to say that when i repaired my speedo plastic needle with electrical heat shrink, it eventually desintegrated and my speedo failed to work again.
I have since purchased a new gtr speedo cable brand new from nissan at 90 bucks trade price. spent about 2 hours removing and refitting, if anyone has done it, OMFG I HATE THE TRIANGLE BIT.
On a related issue, done anyone have a probelm when the go above a speed limit and the needle kinda "sticks" then moves, "sticks" then moves? ie. its not smooth movement? mine seems to do it after 110. really gay, but not a big issue as im a good boy and stick to the 110km/h limit :D:P
  • 3 weeks later...
may be a dumb question but on the dash end of the speedo cable, is the white plastic thingy with the spring inside it ment to be attached to the metal end of the speedo cable housing? or does it just sit in there on top of it freely? i can just pull it straight out??
cheers
Josh
Edited by Josh_r32
actually its part of the cable and should not come out if its new.. sounds like you got the problem we have all had... soon it will get stuffed and you will have to let nissan hold onto your wallet.
bye bye
thanks, so if i get a new cable it will come with the plastic bit with the spring inside it etc all attached?
Edited by Josh_r32
yep about 100 bucks. if you check my SIGNATURE, i will have u the part number tonight. about 10pm brisbane time.
Edited by arbess
  • 3 weeks later...
On a related issue, done anyone have a probelm when the go above a speed limit and the needle kinda "sticks" then moves, "sticks" then moves? ie. its not smooth movement? mine seems to do it after 110. really gay, but not a big issue as im a good boy and stick to the 110km/h limit :):D
Yep. Yours will probably also do it at really low speeds, like <30kmh
And yeah, totally ghey. I thought it only happened with old speedo cables though? Weird.
  • 1 month later...
Would the speedo cable be suspect in my case?
This happens 80% of the time when driving. My speedo needle MOVES, but it moves not in accordance to the speed i'm actually doing. So for example, i accelerate to what 60kmh should be and its hovering around the 180-190+ mark. If i do 100, it moves all the way round and stops at the bottom of the rest pin.
Once in a while it'll go back to normal and show the correct speed. Then 5 mins later it's doing crazy stuff all over again.
I also have no idea how to get the cluster out to check it. Is there a tutorial on this?
Yes and yes. :rolleyes:
Tutorial to get your dash cluster out:
http://www.skylinesaustralia.com/forums/in...howtopic=115618
Haven't seen one for replacing the cable but there are lots of threads with references to doing the job.
HTH
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 馃槷 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
