All i can say is SH*T... went to remove the speedo alert at the back of the cluster and must have snapped the plastic needle that went in2 the back of the speedo wen refitting. Notice speedo wasnt working then power steering so sounds like the same sh*t. guess i need to buy a new cable just cause of that... GREAT
  • 4 weeks later...
  • Replies 50
u generally snap the plastic bit that goes into the back of the cluster because u dont line it up properly when u put the cluster back in or take it out an slightly the wrong angle!! its the dumbest thing invented i reckon...wtf do u need a spring loaded piece of plastic on ur frigging speedo cable!!
i changed mine...wat a bitch!! lets go find the dude who invested plastic speedo cables..HAHAHA
  • 3 weeks later...
  • 2 months later...
May be a dumb question but my mates speedo stopped working then about 10 mins later his power steering cut out and would stay off until the car was switched off, then it would work again for a little while.... Tonight my speedo stopped working then about 10 mins later my power steering did the same thing, is this a common thing too, or just a very weird coincidence?????
same problem with me,
do i have to replace the speedo instrument cluster as a whole or just the speedo cable?? how do i know if the speedo cable is gone and is the problem?
Remove the instrument cluster and look at the end of the cable, you should see a square drive pin sticking out. If not it will most likely be still stuck in the back of the cluster instead of being attached to the cable end. If it is there and isn't loose, move the car a few meters and you should see the pin turn, this is to ensure that the drive from the gearbox and the cable itself is all ok. bets are on cable end..
takes more than 5 mins to fit dude
instrument cluster and shit has to come out as well as all the trims that go around it
then theres a plate on the fire wall thats need to be un-bolted which is in a shit spot
$80 sounds right to me
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
