hey all kinda new to these forums there great, i was wandering how much hp a stock r33 is im looking at getting a r33 gtst with a hks exhaust,air filter and blitz blow off valve, anda m spec front soon 93 model, but yea i was wandering if anyone knows the horsepower for a stock 33 thnx for your time
https://www.sau.com.au/forums/topic/97686-question-on-stock-r33-gtst/
classic skylines.....see that up there ^^^ that means old.........something r33's are not....im moving your thread to where someone might give a rats a55
next time....look what subforum you are in before posting irrelevent questions....
I'm moving your post.
now go to skyline specific discussion like a good little boy....
maybe i was harsh, i dunno, but ive had an absolute ass of a day.......and you pi55ed me off.
that is all.
dont do that mate. are u in QLD? coz thats where that particular mod is, and also being an older skyline owner. ive never seen him on the forum before
this is not being disrespectful to the mod above, im just saying dont not come onto this great skyline forum because you dont like 1 person that you will probably very rarely come across again
Sammie dont worry mate i f**ked up all the time when i first got on here champ so dont let it bother you and i think it was more of a piss take if you ask me
funny when you have your car 4 a while
wecome any way champ
james
A stock R33 depending on SI or SII will make say about 150kw at the rears.. maybe a little more - maybe a little less depending on how it has been driven..
yer thnx peeps due to that asshole of a mod - not exactly the nicest thing to say yourself..
anyways - stick around it's all good once you know where everything is - especially the search button..
happy with your car?
  • 3 years later...
hey dude i own a black r33 gtst and now have done a few mods to em. in stock form there about 150kw at the wheels. i have now done 3 1/2 zorst apexi safc2 pod tomei exhaust ajustable cam gear with exhaust cam offset 5 deg. removed vvt and a few other mods and on stock boost and a sliping like hell clutch (witch should have been my first upgrade cause now cant use the power) i made 185 rwkw with 675nm tourqe witch with stock boost and turbo i was very happy with. hope that helps :dry:
Edited by cuttz
    • To plug the hole. The engine plant may not have known whether the car it was going into had a gauge or not. It was a long time ago and the integrations might not have been fully modern. Or they might not have cared because the extra inventory and processes to save a few cents on the sender might have cost more anyway. But please tell me you are not still confusing the idea of a pressure gauge sender, and an oil pressure light switch. The switch will be out there. In a separate hole. Probably with only one wire running to it. Running the light.
    • Blower needs to go low on the exhaust side, displacing the AC and PS, which you have to decide whether you want to keep and how and where to relocate if you do. Electric option for PS is, at least, helpful. Sadly, there is no workable 12V electric AC of any value. Whilst the blower is the last compression step before the throttle, and so it might seem a good idea to have it near the inlet manifold (as mentioned above), you probably want it to go through an intercooler first, so, having it on the opposite side of the car facilitates that air flow path. The turbo discharges into the blower, so proximity of the turbo's compressor outlet to the blower's inlet is nice. But then you might want to intercool that too, before boosting it again....which would probably be a ball ache. Routing pipes out to the front and back could be a bit shit. If there was room for (at least) a small (but preferably larger) water to air core on that side, then that would probably be the best approach. I guess a reasonable alternative would be to locate the blower where the alternator is (more or less, associated with the inlet manifold, per Matt's thought), and somehow incorporate a water to air core into the manifold, sort of like they do for modern blown V8s. The big difference here though is that those V8s have only the one throttle (upstream the blower) and only the one compression step (the blower) and no need for too much in the way of bypass/blowoff valves. Whereas in a twin charged 6, you do need to think about one or two bypass valves associated with the 2 compressors and you would prefer to have the intercooling done before the air has to pass through the throttle. You'd like the throttle to work approx the same no matter what the compression is doing. But if it is located in hot air stream before a cooler, then sometimes the air will be real hot, sometimes it will be quite cool, and the throttle mapping/response will be quite different between those two cases. The throttle, if sized for hot air, would be too large for cold conditions. It's all a ball ache.
    • Package SC on exhaust side. Remote mount turbo. Still a fair bit of room when you get creative on the inlet side of the motor too. Especially if you can get really creative with the welding, and effectively build it into the bottom of the inlet manifold. Would definitely take some design work, and some trial and error, to make sure flow works well still! Might be easier to just start with the Nissan March though... All the work is already done for you...
    • I'll sit down and get a post together 😁
    • The factory oil pressure sender is no longer in the car that's what is confusing me. In the Taarks adapter I have an aftermarket Bosch style pressure/temp sender and the factory temp sender only. Oil pressure is perfect. Where does the factory oil temp sender go to if there were never any gauges? Why was it there from the factory?
