I have a 95 r33 gtst...
Its had a shitty idle for quite a while. Ive attached a link to an excel sheet with a datalog from the nissan datascan software.
It shows a warm start, idling for a moment, then easy acceleration to 100km/h.
I would really appreciate it if I could get some opinions on it. The only thing I notice is the very very unstable timing at idle.... but what on earth could be causing this??
Thanks in advance.
Datalog
https://www.sau.com.au/forums/topic/97689-check-out-my-datalog-please/
Is the value of AF Base the learned AF correction? In which case it is quite lean. Check the O2 sensor grounds and its bias with chassis and ECU ground. Also maybe a noisy crank signal. Try running another ground to the CAS. If this dosn't work try one from another car.
  • 4 weeks later...
Ok, swap tested the CAS.... same deal. WHY!?
Not the AFM, O2 sensor, plugs, coils, battery, CAS, AAC valve. I tested the A/F ratios with a wideband O2 sensor & they were spot on too.
I got a shit idle, no power, and my ignition timing is all over the shop.
I'm gonna drive the f**ker off a cliff!!!!
The pfc uses ign in an attempt to lower idle in conjunction with the AAC.
This is what it looks like it is trying to do.
Whats your base idle set to in the pfc?
I would disconnect the aac and reset your idle when warm to as close but ensure its not over the pfc's set idle a/c off. Reconnect the aac.
Init the pfc, load in your maps, start the car and send it through the 30min idle learn. For the next few days it will still occasionally play up, let it do its thing then all of a sudden you will think.. oh shiet its idling perfectly smooth.
DO NOT attempt to change the idle rpm as it will bugger it up and you will constantly have a crap idle from then on. For some silly reason I've always had to init the pfc for it to relearn the idle properly.
If this doesn't work ensure your aac is clean from gum (remove and pull apart, soak and clean) Also ensure the solanoid is working. Hitting the A/C button is an easy way to test, idle should raise, same with turning your power steer.
I would then attempt swapping of the cas and all the other harder and more expensive solutions. :nyaanyaa:
Edited by Cubes
mate, i cant set a base idle.... doesnt matter how i adjust the cas, the timing will jump everywhere at idle. I have tested my datascan cable & software on another r33 & got a rock solid 15 degrees...
plug gap is .8
cubes, i actually have a pfc by the way... havnt had it tuned yet coz i wanna sort this shit out first... but i CANT!
Edited by Mickroy
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
