For Sale: Injectors, Z32 AFM, Fuel Pump and Chip to suit
Guest white180sx
I have a few Badbiki Daughterboards with Performance Maps for Z32 AFM
and 550 or 740cc injectors.
I also have a few sets of 550cc injectors and another set of 740cc
injectors
Larger Fuel Pumps
Z32 AFM (good for 550ps)
with the 550cc injector combo good for 400hp
and 740cc injector combo good for 540hp
I can also get hold of larger injectors and fuel pumps for even
higher applications.
can supply for CA18DET, SR20DET, SR20DE, RB20DET, VG30DETT
All maps are tuned in for performance and Fuel maps are still on the
rich side for durability and safety reasons as some cars run leaner
than others.
I can get brand new Garret Ball Bearing turbo's at a good price.
E-mail me or PM me for more info. E-mail: mdill@i...
Injectors have been desluged and cleaned and flow tested.
Brand new and reconditioned Fuel Pumps your choice
Reconditioned AFM
Guest white180sx
I have a set of 550cc RX7 Injectors I also have the clips for these injectors. what car is the 550cc injectors for?
I am not sure what injectors I have for the RB25 there are two types of ecu's for the rb25det, one has a 27C256 eprom and the other has the H8 CPU, the only way to tell is pull the cover off the ecu and have a look it will be a rectangled eprom if it is, I can reprogram a performance map for you aswell which will suit the Injectors.
im after a set of 550cc RX7 high impendence injectors also for my RB20DET... red or purple tops. how much? also how much for a larger fuel pump?
email me [email protected]
white180sx,
do you know the part number for bosch 550cc or larger injectors? NOONE in the industry will tell us, only want to sell us a set. if you can help, please let me know,
thanks
  • 6 years later...
Hey i'm looking for an eprom chip for my rb20, i need it tuned for 550 injectors and z32 Mass air sensor. If you could let me know if its possible and shoot me a price to [email protected].
Thanks Brian
Thanks Brian
thread is over 6 years old
Thanks Brian
Nice first post brian.
Try putting a thread in the wanted section.
Hey There I am after 2 set s of 740cc injectors Top feed to suit standard R33 GTR RB26 fuel rail and plug fittings.. What brand are the ones you are selling and how much? I am in the UK by the way.. Hopefully you can ship?
Thank you
Lee
