For Sale: Injectors, Z32 AFM, Fuel Pump and Chip to suit
Guest white180sx
I have a few Badbiki Daughterboards with Performance Maps for Z32 AFM
and 550 or 740cc injectors.
I also have a few sets of 550cc injectors and another set of 740cc
injectors
Larger Fuel Pumps
Z32 AFM (good for 550ps)
with the 550cc injector combo good for 400hp
and 740cc injector combo good for 540hp
I can also get hold of larger injectors and fuel pumps for even
higher applications.
can supply for CA18DET, SR20DET, SR20DE, RB20DET, VG30DETT
All maps are tuned in for performance and Fuel maps are still on the
rich side for durability and safety reasons as some cars run leaner
than others.
I can get brand new Garret Ball Bearing turbo's at a good price.
E-mail me or PM me for more info. E-mail: mdill@i...
Injectors have been desluged and cleaned and flow tested.
Brand new and reconditioned Fuel Pumps your choice
Reconditioned AFM
Guest white180sx
I have a set of 550cc RX7 Injectors I also have the clips for these injectors. what car is the 550cc injectors for?
I am not sure what injectors I have for the RB25 there are two types of ecu's for the rb25det, one has a 27C256 eprom and the other has the H8 CPU, the only way to tell is pull the cover off the ecu and have a look it will be a rectangled eprom if it is, I can reprogram a performance map for you aswell which will suit the Injectors.
im after a set of 550cc RX7 high impendence injectors also for my RB20DET... red or purple tops. how much? also how much for a larger fuel pump?
email me [email protected]
white180sx,
do you know the part number for bosch 550cc or larger injectors? NOONE in the industry will tell us, only want to sell us a set. if you can help, please let me know,
thanks
  • 6 years later...
Hey i'm looking for an eprom chip for my rb20, i need it tuned for 550 injectors and z32 Mass air sensor. If you could let me know if its possible and shoot me a price to [email protected].
Thanks Brian
Thanks Brian
thread is over 6 years old
Thanks Brian
Nice first post brian.
Try putting a thread in the wanted section.
Hey There I am after 2 set s of 740cc injectors Top feed to suit standard R33 GTR RB26 fuel rail and plug fittings.. What brand are the ones you are selling and how much? I am in the UK by the way.. Hopefully you can ship?
Thank you
Lee
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
