For Sale: Injectors, Z32 AFM, Fuel Pump and Chip to suit
lol fock sakes. i always do that when i sign up on new forums trying to figure out where everything is i never look at dates. Just do a search and start posting lol.
Atleast you actually used the search function.
Hey There I am after 2 set s of 740cc injectors Top feed to suit standard R33 GTR RB26 fuel rail and plug fittings.. What brand are the ones you are selling and how much? I am in the UK by the way.. Hopefully you can ship?
Thank you
Lee
Your an idiot.
Correct me if I'm wrong but don't the rules state you must put a price up for these?
Your an idiot.
