FILO34 Posted December 7, 2005 Share Posted December 7, 2005 Just wondering if the R33 GTST stock suspensions fit the R34 GTT? Any Help would be great. Thanks, Kris Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/ Share on other sites More sharing options...
Sydneykid Posted December 7, 2005 Share Posted December 7, 2005 Just wondering if the R33 GTST stock suspensions fit the R34 GTT?Any Help would be great. Thanks, Kris <{POST_SNAPBACK}> Nope, the rear shocks on R33GTST's have bushes at the bottom and R34GTT rear shocks have forks at the bottom, like an R33GTR. cheers Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1771985 Share on other sites More sharing options...
FILO34 Posted December 8, 2005 Author Share Posted December 8, 2005 Cheers mate... Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1777475 Share on other sites More sharing options...
benl1981 Posted December 9, 2005 Share Posted December 9, 2005 Do the fronts fit?? I mean will a R33gtst be able to take R34 GTT shocks Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1778202 Share on other sites More sharing options...
Sydneykid Posted December 9, 2005 Share Posted December 9, 2005 Do the fronts fit??I mean will a R33gtst be able to take R34 GTT shocks <{POST_SNAPBACK}> Yep cheers Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1778253 Share on other sites More sharing options...
benl1981 Posted December 9, 2005 Share Posted December 9, 2005 So I could look for some second hand R34 front shock/spring assemblies and wack them in my R33? Same ride height after you think? Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1778258 Share on other sites More sharing options...
Sydneykid Posted December 9, 2005 Share Posted December 9, 2005 So I could look for some second hand R34 front shock/spring assemblies and wack them in my R33? Why? They are no better than standard R33GTST parts. Don't let the possible K's of an R34 fool you, they aren't that good, even when new. Same ride height after you think? Most likely, since they are both ~375 mm centre of wheel to guard when new. cheers Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1778399 Share on other sites More sharing options...
benl1981 Posted December 9, 2005 Share Posted December 9, 2005 (edited) Thanks SK - can you get just the fronts in bilsteins ? Ill check the group buy Will having only the fronts being adjustable be any benefit? Could I put my standard springs on the bilstein shocks? Edited December 9, 2005 by benl1981 Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1778407 Share on other sites More sharing options...
benl1981 Posted December 9, 2005 Share Posted December 9, 2005 Does anyone know where to get Kybs or monroe cheaper than $130+gst each? I think I'm going to go povo option. I think the reason the standard shocks dont last long is because of the crappy dust boots. Almost all R33s have none existent boots by now. All that dirt getting in couldn't help... Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1778665 Share on other sites More sharing options...
Sydneykid Posted December 9, 2005 Share Posted December 9, 2005 (edited) Thanks SK - can you get just the fronts in bilsteins ? Ill check the group buy Will having only the fronts being adjustable be any benefit? Could I put my standard springs on the bilstein shocks? <{POST_SNAPBACK}> No problems, the Bilsteins come in pairs, plenty of guys have used them with standard springs. The extra circlip grooves mean you can set the height a little lower even with standard springs. Not too low though as the standard spring rates are not designed for short travel, I think the reason the standard shocks dont last long is because of the crappy dust boots. Almost all R33s have none existent boots by now. All that dirt getting in couldn't help... It is actually the other way around, the shocks wearing out means there is no compression damping and they get excessive bump stop contact. This constant pounding on the bump stops wears them out and causes the dust covers to get trapped and torn by the up and down motion of the shock shaft. cheers PSl; the Bilsteins aren't rate adjustable, they have a large enough damping window to handle it. Edited December 9, 2005 by Sydneykid Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1779428 Share on other sites More sharing options...
benl1981 Posted December 9, 2005 Share Posted December 9, 2005 WHat difference in handling would I notice with just the front shocks being bilsteins - would this be worth it you think? Thanks SK. Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1779471 Share on other sites More sharing options...
Sydneykid Posted December 10, 2005 Share Posted December 10, 2005 WHat difference in handling would I notice with just the front shocks being bilsteins - would this be worth it you think?Thanks SK. <{POST_SNAPBACK}> The front is 60% of the total weight, so the improvement is very noticeable. More control, better turn in, less dive under brakes, all the usual things you get from using decent shocks. You can always upgrade the rear later on. cheers Link to comment https://www.sau.com.au/forums/topic/97697-does-r33-gtst-stock-shocks-fit-r34-gtt/#findComment-1780140 Share on other sites More sharing options...
