bastard !! you got the kit I WAS going to get....hehe
nah looks nice...love the carbon canyards...
was going to go for a URAS kit too...but too many people with 34s have got them now....so im going for something a little different.
is your kit made of that new flexible material those MFX boys have got these days ?
Edited by shonen
https://www.sau.com.au/forums/topic/97700-new-r34-bodykit/#findComment-1772433
mad34: Cheers mate!
shonen: Yeah its made from the MFX M-Flex stuff.
Also you wont find anything like this to fit perfect with no dips under the head light, ripples and all. And with the flexable stuff it works out better.
Cheers guys...
https://www.sau.com.au/forums/topic/97700-new-r34-bodykit/#findComment-1772600
looks good...not a fan of that type of wing tho...but the rest is nice  :P
I like the wing..got one of those as well...~~ what's wrong with the T-wing~~hehehe..aside from it looks really low from some angle
I like the bonet thingy..and dun think can get a yellow sticker for that...
https://www.sau.com.au/forums/topic/97700-new-r34-bodykit/#findComment-1775396
Yeah, T-wings are great, i dont mind them. The R34's look good with
or with out wings.
The bonnet, never got defected for the vent its self but depending on how
you cut the bonnet frame then you may get it trouble.
Just the bonnet screw fittings i got done for, as mine was not a rounded
top fitting/nuts/bolts.
https://www.sau.com.au/forums/topic/97700-new-r34-bodykit/#findComment-1777490
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
