hi guys
we just got the car back from a very good tuner and it isnt making enough power for the goodies on it.
we also took the car to another very good tuner and he had the same problem
the car is making 252 rwkw.
here are the mods
R33N1 ENGINE (6000 K'S OLD)
R34 N1 TURBOS
GREDDY CAM WHEELS
TRUST 4INCH EXAUGHST FROM TURBO BACK
HKS DRAG INTERCOOLER 105MM
APEXI POWER FC
800 CC SARD INJECTORS
AFTERMARKET TURBO INTAKE PIPES
Z32 AIR FLOW METERS
APEXI AIR PODS.
AFTER MARKET INTERCOOLER PIPING
CATCH CAN
should we be making more power? or am i over stating?
does anyone have any suggestions as both tuners have checked everything and cant find anything wrong with it
thanks guys
cheers
https://www.sau.com.au/forums/topic/97701-not-enough-power/
Upgrade the turbo's from R34 N1's? Snowman is running N1 and is making more power than that.
Just as another note, one of the Vic board members cars, an R33 GTR is making 260rwkw, with a standard engine, cam gears, hard pipes, 1bar boost, 4" exhaust and pods with standard AFMs.
I would expect more power than that. What boost level are you running? How did they set up the cam timing? What does the ignition plot look like? Standard boost controller?
https://www.sau.com.au/forums/topic/97701-not-enough-power/#findComment-1772326
hi guys
here are the mods
R34 N1 TURBOS
GREDDY CAM WHEELS
APEXI POWER FC
Z32 AIR FLOW METERS
APEXI AIR PODS.
CATCH CAN
thanks guys
cheers
Shouldn't you making 350kw+ ?
https://www.sau.com.au/forums/topic/97701-not-enough-power/#findComment-1772370
i would think that combo should be good for 300-350rwkw. i'm making 1 kw more than you with only:
32 engine
stock 32 turbos
hard pipe kit
cam gears
pods
cat back exhaust (front half still standard)
1 bar boost
power FC
https://www.sau.com.au/forums/topic/97701-not-enough-power/#findComment-1772419
we are running 15 psi and it has been to both ben and nizpro
15psi is why you are making 252rwkw's.
To get upto 300kw+ you'll need to increase the boost to 19-20psi.
My car on stock turbo's at 15psi was making 255rwkw's. The N1's are basically the same just a steel wheel which should be able to hold more boost. If you have stated 15psi as a max then the power you have got is what you should expect.
If you want more power wind up the boost.
Cheers.
https://www.sau.com.au/forums/topic/97701-not-enough-power/#findComment-1772442
Wasnt the reason the car was not tuned with more than 15psi the first time because it was expiriencing detonation??????
And that was more than likely due to the choice of fuel that was used i thought?
Bit hard to say its not making the power that it should if you aint putting decent go-go juice into the tank and screwing boost into it.
Its making spot on power for what your running it at essentially.
https://www.sau.com.au/forums/topic/97701-not-enough-power/#findComment-1772584
i would have thought that unless you are living in a remote area there is no reason not to run 98 octane fuel in a modified car.
will give plenty more headroom for your tuner to run more boost without the detonation you've been seeing using the crappy 95 ron.
https://www.sau.com.au/forums/topic/97701-not-enough-power/#findComment-1774140
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
