Putting 98 RON fuel should allow you to wind the boost up a bit higher before it starts to ping at all (much)..
why were you tuning the car on a mixture of 95/98?
it was tuned at bens and on his dyno got to 232rwkw, but on another it only got 212rwkw, the problem has been fixed now it seems that the stock boost is actually 12 psi so turning it up a bit should see the power go up,
thanks for your help guys and snowy
cheers
R34 N1s are not the same as standards but just with steel wheels. They are very different on the exhaust side with .64 A/R rear housing compared to .48 A/R for the stockies. they also have different size and trim wheels, and a ball bearing centre and a built in seperater in the exhaust housing to seperate the wategate flow. There is no reason with 18-20psi and the right tune that you can't make 330rwkw+ with those turbos. The 34 N1s are very similar to a GT-SS. Some '34 N1s' i've seen also have a .60 A/R comp cover which makes them pretty close to a 2530. They are a pretty good turbo for a street GTR.
the question is: are you sure they are 34 N1s?
yes we are sure, we have looked at them from undeneath and that is what was specified that was on the car. you can here them wind down they are definatley roller bearing.
I would have thought that with R34 N1 turbos you would have no chance of reaching 300rwkw, unless you were running some rediculas boost, say 28psi :D , and this will probably be past their efficience range.
A descent set of cams would probably solve the problem :(
I think you'll find that 34N1's are similar to GT-SS's, and would comfortably make 300rwkw on 20 psi, I doubt it very much they'll reach 330rwkws unless your running cams, big boost and good fuel or do a run in shoot-out :( . Take into consideration each dyno is different, but going by what Ben tells me they're rediculously responsive down low but do suffer a bit up top.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
