Hi
Anyone know how hard or easy it is to change the hydraulic fluid for the transfer case for the attessa? mines sprung a leak where the hose that leads into the transfer case. Is it just a gasket that needs to be replaced and then the fluid that is lost replaced? Also the type of fluid to use? Anyone have previous experience and knowledge would be appriciated. thanks
https://www.sau.com.au/forums/topic/97716-gtr-attessa-hydraulic/
the hose that goes into the transfercase actually just feeds pressurised fluid into the actuator that is mounted at the back of the transfer case. the transfer case has it's own fluid that you service, one drain plug and one filler plug. attessa actuator reservior should be in the rhs of boot behind liner.
Use nissan automatic transmission fluid - can't remember what is called sorry... Nissan will know tho..
EDIT* Just reread the first post - use the tranny fluid for the attessa reservoir - not sure what for the transfer case...
Edited by Josh
Thats right, auto trans fluid from the boot resoviour.  From memory theres no gasket just a screw in fitting.
ok kool thanks ...if iam doing that myself to change the fitting...i presume i will lose fluid from the boot resevoir so i may as well do a serive n drain and change it, but what kind of fluid do i use to replace? would nissan sell them??
ps: duncan i want to purchase the attessa controller of you if u have any available still..still waiting to get my other car ready so can use on that. cheers
yeah but if i take that hose that is bolted on to the transfer case with two bolts out n replace with new gasket i presume...which fluid will come out? from the boot resevoir on driver side?
First undo the pipe the goes into the rear of the transfer case ( 14 mm pipe spanner if i remember right ) , block the end of it so you don't loose fluid ( if you dont want to change the fluid in the boot ) , then undo the little plate where you say its leaking and seal it with a gasket or liquid sealant , reinstall the reverse order .
If you want to change the fluid in the transfer case undo the plug under it and drop it out then undo the filler plug on the side and fill until it starts coming out .
If you want to replace the attessa fluid , undo the little bleed nipple under the boot on the drivers side ( under the car where the reservoir is )and let it drain out . Fill the tank in the boot to max and then you have to bleed the system while you keep an eye on the tank to make sure it doesn't run low .
To bleed the system you have to activate the attessa pump , yopu will find that you have to find a plug under the dash , near the steering ( refer to the workshop manual as to what you have to do , not sure on the 32 , i cant remember ) .
Once the pump is going you undo the bleed nipple on the transfer case for a second and do up again , repeat until there is no more bubbles in it .
If you dont bleed the system the attessa wont work as its meant to , you have to bleed the system everytime you pull the g/box down to do a clutch as well .
You can use Nissan matic-d auto fluid in both , i dont , i use dextron III .
I hope that helps you .
Correct Richard , same in both mate , but Nissan have the oil as well but they know how to charge .
Make sure you bleed it though , some people have trouble geting the screw plugs out so make sure you can undo the fill plug first before you let the oil out of the trasfer case .
yes! wise advice. i made that mistake once before, drained out a gearbox then couldn't open the farking fill plug. the oil still all drained out i guess as there was enough air coming in through the breather. eventually we got the filler open but it was a nervous moment.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
