Well I have decided the body kit isn’t going to happen for a while so I have decided to sell my Vertex body kit instead of holding on to it for future plans
I only have the side skirts and rear bar but the front bar is easy enough to hold of as some sponsors have the front already
The price is firm but will also consider trade for aftermarket R32 suspension
$700
Located eastern Vic
Prefer not to send interstate, as item is fairly large but will consider at your own cost
https://www.sau.com.au/forums/topic/97730-fs-r32-4-door-sedan-vertex-kit/
Hmm...just registering my interest for a kit to mod for my cressida. Could you by any chance throw a tape measure over the skirts for me to see what length they are?
Cheers,
Troy
Edited by Bowlsclubboy
  • 1 month later...
  • 4 weeks later...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
