Yer that was me in the 34 I am a member here but I don’t come on here much.
yer it goes ok for now, better soon  :)  it has 239rwkw @.8bar. yer my zaust is small but is a twin 2,1/4 system off the front pipe no mufflers :O
Hmm..239 rwkw???
How on standard turbs? and just power fc and front mount?
what mods do u have?
sounds too good to be true..
that or something is wrong with my set up..
:O
Edited by Iceduck312
  • Replies 71
Posted Images
Nah not standard turbo it has a Trust kit with lots of other goodies :)
Trust fmic
Trust airnx pod
Trust turbo kit
Trust can gears (still to go on)
Trust 1.2mm h/gasket (still to go on)
Apexi power fc
HKS electronic boost controller
Walbro 255 pump
NGK irdium plugs
3inch f/pipe into 2x 2,1/4 straight pipes
and som other little things
just want a good clutch!
mad34 pm sent
Edited by gtst93
  • 1 year later...
Im still alive, bought my r34 in Melbourne, it was resprayed GTR purple in Japan, I think its up north of SA now and its still around in one peice which is good to hear.
As for me Ive bought a corolla sportivo... now before you laugh I get 720 KMs to a tank and it has 150 kw from factory... check out how they go here.
Cell (Damian)
I thought tat colour was only avaliable on R33 GTR, think he told my mate a dude in melbourne got it sprayed that colour, Damian got it from him.
I rented a corolla for the last week at sunny coast and struggle to get more than 550km with plenty of highway travel :)
it's not the vvt-li 1.8L like yr's but they still goes pretty good, much rev happier than my line
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
