(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
Item:
Item Condition:
Reason for Selling:
Price and Payment Conditions:
Extra Info:
Contact Details:
brand new c's short stroke shifter to suit ecr33
price is $350 plus postage if app
im located in nth ringwood melb vic
contact no is 0422396325
ITEM SOLD THANKS
Edited by rev zone
https://www.sau.com.au/forums/topic/97784-cs-short-shifter/
Item:
Item Condition:
Reason for Selling:
Extra Info:
Contact Details:
price is $375 plus postage if app
bump
bump
Edited by rev zone
https://www.sau.com.au/forums/topic/97784-cs-short-shifter/#findComment-1779106
do you have you original reciept for it? why are you selling it?
I'm looking into buying a genuine C's short shifter from Japan, but for the right price i'd be happier to buy one here, save waiting.
PM me your lowest price, i could pick up, or meet you in CBD?
https://www.sau.com.au/forums/topic/97784-cs-short-shifter/#findComment-1787116
Item:
Item Condition:
Reason for Selling:
Extra Info:
Contact Details:
bump
https://www.sau.com.au/forums/topic/97784-cs-short-shifter/#findComment-1814139
Item:
Item Condition:
Reason for Selling:
Extra Info:
Contact Details:
bump
bump
https://www.sau.com.au/forums/topic/97784-cs-short-shifter/#findComment-1827146
Item:
Item Condition:
Reason for Selling:
Extra Info:
Contact Details:
bump
https://www.sau.com.au/forums/topic/97784-cs-short-shifter/#findComment-1847228
  • 3 weeks later...
Item:
Item Condition:
Reason for Selling:
Extra Info:
Contact Details:
bump
https://www.sau.com.au/forums/topic/97784-cs-short-shifter/#findComment-1897360
  • 3 weeks later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
