Hello all,
I need help identifying my turbo, its stamped Garrett a/r .53 1-2
I've done a search for a while and have come to the conclusion they're not stock or N1's.
The turbo itself is fairly small and looks similar to:
http://image-cache.skylinesaustralia.com/f...-1128568610.jpg
Any help in identifying which turbos they actually are / possibly could be, or any information would be much appreciated.
SNG. :P
https://www.sau.com.au/forums/topic/97809-which-garrett-turbo-is-this/
Hello all,
SNG.  :P
I think you will find they are stock units from an R34.
well the turbo in the pic you posted is a stock 32/33 GTR turbo (.42 A/R) i don't know much about 34s, but i guess it's possible they had .53 A/R compressor covers.
edit: they are definately not an N1 i've ever seen though as they all had either .48 or .60 A/R comp covers with a .64 A/R turbine housing.
Sorry guys i probably confused u with the photo in my first post, i put that in there as my turbo looks similar to that, its not an actual photo of my turbo.
The best photos i can get are below which u really cant see very well as there still on the car, and its taken with a camera phone so its not the best quality or angle.
Can anyone confirm if they are r34 turbo's?
I cant seem to find any info on an a/r .53 spec turbo. :rolleyes:
Thanks for the help so far! :)
So were agreed they are turbos from a r34 gtr?
Whats the max boost i should run these at seeing they have a ceramic exhaust wheel, 1bar? I assume they're prone to shatting themselves if run at sustained high boost pressures?
Anyone know maximum flow of these turbos?
Cheers! :D
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
