You don't have cats in your neighbourhood, do you? Maybe the local tom has decided he likes your car and 'marked' the air intake vent.
You can get little air-fresheners that will clip on the vents and circulate sweet smells through the car.
Guest RedLineGTR
Aircon disinfectant cleaning spray, there are sprays on the market to remove the smell, the smell is because of bacteria and mold & fungus are growing in the ducts. This is because when you run you air con, and instantly turn it off the moisture is stuck in the vents thats why they recommend you letting the fan run for a little while after the aircon is off. Best bet is to go to any auto parts shop, like autobarn or something like that and just tell em what the problem is. Or even a aircon repairer shop they are a good bet. Hope i've helped.
Cheers
Guest RedLineGTR
Originally posted by hippy
it isn't that bad .. just when i turn it on it has that smell ... so after a while it goes away ...  does auto barn sell this disinfectant spray?? if so ... how much and where do u spray it??
Just to a auto part shop ask em about it most of them can get it in buy the next day. The propper way to do it is get them professionally cleaned out but a aircon place as stated above.
most of the time you have to wash the evaporator coil.got a japanese product called crystal waters.
in the old days of rotting heater cores we used nil-odour.small eyedropper full in the fan motor.
tried sprays,some work,had one with a long tube and expanding type foam.glen twenty is probly best.
silly people often let it fill with leaves.and the things grow in there big time.
i can't recalling ever pissing in the air vent ... although i will jog my memory ... i will go to a place to get it cleaned out .. do i have to go to a proper place or can any mechanic do it for me ... can i go somewhere where they can regas air cons?? would they know how to do it??
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
