You don't have cats in your neighbourhood, do you? Maybe the local tom has decided he likes your car and 'marked' the air intake vent.
You can get little air-fresheners that will clip on the vents and circulate sweet smells through the car.
Guest RedLineGTR
Aircon disinfectant cleaning spray, there are sprays on the market to remove the smell, the smell is because of bacteria and mold & fungus are growing in the ducts. This is because when you run you air con, and instantly turn it off the moisture is stuck in the vents thats why they recommend you letting the fan run for a little while after the aircon is off. Best bet is to go to any auto parts shop, like autobarn or something like that and just tell em what the problem is. Or even a aircon repairer shop they are a good bet. Hope i've helped.
Cheers
Guest RedLineGTR
Originally posted by hippy
it isn't that bad .. just when i turn it on it has that smell ... so after a while it goes away ...  does auto barn sell this disinfectant spray?? if so ... how much and where do u spray it??
Just to a auto part shop ask em about it most of them can get it in buy the next day. The propper way to do it is get them professionally cleaned out but a aircon place as stated above.
most of the time you have to wash the evaporator coil.got a japanese product called crystal waters.
in the old days of rotting heater cores we used nil-odour.small eyedropper full in the fan motor.
tried sprays,some work,had one with a long tube and expanding type foam.glen twenty is probly best.
silly people often let it fill with leaves.and the things grow in there big time.
i can't recalling ever pissing in the air vent ... although i will jog my memory ... i will go to a place to get it cleaned out .. do i have to go to a proper place or can any mechanic do it for me ... can i go somewhere where they can regas air cons?? would they know how to do it??
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
