Hey guys,
Tomorrow I'll be replacing my rocker cover gaskets and the semi-circle rubber seals at the back. I just have a few questions:
1. Is there any special method of cleaning the surfaces before putting on the new gaskets?
2. What sort of adhesive do I need to put on the semi-circle rubber seals and where can I get it?
EDIT: 3. Should I replace the grommets on the screws that hold the rocker cover down? I don't think Nissan even list them in FAST, all I could find was the washer for the screw but no picture or mention of grommet in FAST.
Thanks everyone.
Edited by ToF
https://www.sau.com.au/forums/topic/97854-replacing-rocker-cover-gasket/
OK I found most of my answers in this thread http://www.skylinesaustralia.com/forums/in...showtopic=71313 by searching indirectly. Sorry about that.
Anyway I'm still not sure if nissan can get those rubber grommets for the screws, anyone done this before and got them?
1. either use degreaser to completely clean the rocker covers or wax/grease remover (or even just petrol) to clean the 'grooves'.
2. 3 Bond is probably best sealer and it's what the factory uses. Burson's carry it.
3. the little rubber washers are available from Nissan (and shown in FAST). Pesronally I would replace them at the same time as they compress and go hard with age.
There should be a thread with info on how to get it and how to install it but I've already forgotten where it is, sorry.
Umm, after I did the job it now leaks oil.... more than before :S
I think I may have tighened the screws too hard, what can I do from here?
Oh shit, I just read the post from 3lit3 32 again...
"I would also recommend getting new rocker cover bolt rubbers as this will help the screws all pull down evenly. They have a flat side underneath that stops when the thread runs out, if the seal is squashed, it won't hold the cover down properly."
Does this mean I should undo the screws until the washers are in original standing state (not squished)???
ah this can be done over and over again and it will still leak. The best way is to use a gasket sealer all the way around. Then start screwing down the screws from the middle and working towards the back of the engine make sure your engine is stone cold when doing this some loctite thread locker may help.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
