Lack Of Aftermarket Parts For R32 Gtr
There are a few kits outthere, i researched it before i resprayed my GTR, but they're very pricey, compared to say GTST or 180, s15 kits.
Apparently it's because the standard R32 GTR kit looks so good as it is. Best front bar of any car IMO. Expose the FMIC, drop the car a bit, chuck on some rims, that's about as much as you need looks wise.
Nismo sideskirts look good if you can get a hold of em.
Peace.
i totally agree, i have full Nismo body kit on my r32 GTR vspec.. side skirts look awesome.. it would top it all off if i can get a vented bonnet , maybe in carbon fibre... even front bumper done in carbon fibre.. would top it all off.
why would you want to put a body kit on a GTR? there is nothing wrong with the way it looks. carbon bonnet is a bit of a wank on a GTR too as the stock one is aluminium so the weight saving may be 1 or 2 kilos for $2K....
Toshi, that bonnet is very nice, but the front bar just looks like a stock one, only worse... hehe sorry but it's true.
The Carbon Bonnet is good for extracting heat out of the Engine Bay richard :(
and re the bar, each to their own I guess :)
that's true, and GTRs certainly can use some heat extraction. i do still want one :)
Guest Mashrock
that's true, and GTRs certainly can use some heat extraction. i do still want one :(
this is the only reason i want one for.
but no body seems to make any with more than that tiny pissy crap looking shit
possibly maybe 15 inch long and smaller than 1 inch gap..
i want one like you can get for the 34.
and i want it now.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
