Fuel Consumption
Hi guys,
I'm looking to buy a stock skyline R33 GTST and curious to know the average fuel consumption. I know these cars are not designed for optimal fuel consumption, but im trying to convince my other half and i need all the help i can get!! :)
I currently drive a BMW 318is and im ready for the power increase hahaha.
I realise the fuel consumption more than likely willnot be as good as the BMW, but obviously, a 6cylinder car never is compared to the 4 cylinder BMW.
Any help would be greatful.
Thanks
Hint: post-18125-1134120881.gif
:):D :lol:
About 2 seconds of searching revealed:
fuel economy
fuel usage for a stock rb25det
I fixed my fuel economy..
Fuel Consumption ???
r33 skyline rb25det Fuel Consumption
Fuel Consumption - help
Hey just wondering about fuel
Fuel Consumption
At this point I got bored... There are many many more threads on this topic already
:):D :lol:
Edited by Big Rizza
Mines horrid for fuel... and its stock, i think it may be tuned by a previous owner to run rich....?
Anyways, i use only 98 octane BP Ult and can get about 300 - 350kms of easy driving to a full tank....
Keep it on boost a lot and it chews it like a sumbitch...
Been keeping a fuel log for the last 6 months. Stock I was getting approx. 12.5lt per 100km. After mild mods (exhaust, boost controller, r34 cooler, safc2) I'm averaging approx 13.2lt per 100km. That's not granny driving either but certainly not going hard.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
