Ok ive been thinking about this conversion for a little while and would like some input/info on what exactly is needed and what needs to be modified to make it fit ?
Some of the questions I have are.
1. Can I use an PFC from a GTR ?
2. If yes for 1. then will it be pretty much plug and play or would there be a lot of mucking around with wiring looms etc ?
3. Heard that the sump needs to be modified to make the engine fit
is this true ?
4. IS the RB26 heavier than the RB25 ? Was told by one person that because of the extra weight it will stuff up the balance of the car. Said it will be quick in a straight line but no good on a circuit..
5. What needs to be moved or relocated...im guess the battery may need to be relocated to the boot.
Thats all I can think of for now......
thanks in advance.
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/
Thanks adam...I wasnt aware that Driver was doing the conversion.
R31. Just with the general trend of things I just thought there would have been a lot of differences between the 33 and 34 to justify a new thread. This has been the case with most parts I tried to get for my car.
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778724
I'd say not really. Im putting a 26 into the 31 and its pretty similar to anyone else's using a later model 32/33
With 26 you'd be getting the whole loom aswell (i hope you are) then its just a matter of buying GTR upgrade bits like PFC and stuff, nice and easy :)
Everyone doing a RWD conversion needs to modify the sump.
ie. remove the GTR diff and weld the hole
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778747
Cool thanks for that nismoid....
but one thing I would like to know is.....is it possible to do this conversion with in a few months ?
Almost all people I have heard of doing an RB26 conversion have taken a year or longer....I cant afford to have my car off the road for so long.
Also I have not seen anyone make any remarks about the weight balance aspects of this conversion and how it affects the car out on the circuit.
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778760
Theres nothing to stop you from doing the conversion in a day, if you've got all the nessicary parts, labour, and knowledge. All comes down to good planning...
In terms of weight I'd imagine a RB26 would be marginally heavier than a RB25, due to the extra turbo and associated bits hanging off the side.
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778761
And it took me a while to do because i just didnt have the time to do it..
It is very possbile to do in a couple of months.. its mostly time consuming
The wiring is the hardest part.
The engine is a direct fit using gt-t engine mounts - gearbox etc fits up fine
You will need custom cooler piping as well as exhaust as you will now have 2 turbos
Thats all i can think of at the moment.
EDIT:
And for those who want to try and make it 4wd you cant as chassi is different and you cant fit the 4wd box.
Edited by Driver
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778835
Spot on. We were gonna have mine done in 2 weekends till we found it had spat a wheel rear turb wheel... added to that JMS must have stored the motor outside for 11ty billion years as ive never seen such a rust covered motor <_<
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1778899
EDIT:
Thanks for that Driver....
Like I said before I have heard that the wiring is a nightmare but is there any sort of wiring diagram available or is it all just guess work ?
and hehe I dont plan to make it a 4WD....I dont need a computer to help me drive.....hhaha well thats my excuse until I can afford an R34 GTR. :lol:
also about the sump....if it needs to be chopped...is that alright for the RB26 motors ?? I heard they need good oil supply especially out on the track and people actually put extended sumps on them...
or am I missing something here ? :D
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1779304
for the 26 into the 31... its not a "large" job. Wiring is the only main thing. And i need to take to my tunnel with a sledge it seems... cant wait for that part.
other than that, bit of piping mods and stuff. 1k for your old motor out, new one in.
Then maybe $1500 to get all the other fiddle stuff like loom changing/wiring etc. I think 2.5k sounds reasonable for labour costs for a conversion. 3k tops
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1779314
Could you fit an aftermarket RB25 sump onto an RB26, or do things just not line up?
People always need to baffle the RB26' OEM sump to avoid oil starvation anyway, so rather than arsing about with the OEM sump when you can just stick a nice baffled, finned and possibly winged sump instead?
Edited by scathing
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1779532
You have to use the RB26 sump, not an RB25 one.
Thier construction is dfferent.
Just get a fabricator who is expirienced @ welding etc to chop the diff off and weld the hole up basically
y do u HAVE too? i know the rb26 one is much much stronger/rigid, but the rb25 one fits with no mods at all and bolts on like stock (different bolt holes though and its like a sheet of tin :blink: )
saves cost of fabrication work if ya on the cheap :) worked on my rb26 in 2wd no problems, and plenty of other do it that way.
cheers
Brad
https://www.sau.com.au/forums/topic/97931-rb26-into-a-gtt/#findComment-1780118
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
