Hi Fellas
Im actually posting on my brothers account as I dont have one on the SAU forums :)
Im using an rb20det turbo (16v-10) on my Honda Civic VTiR, but it just isnt making any sort of decent power like it should. Basically on 10psi on my engine I should be ripping through the stock clutch and spinning tyres easily..
This is all based on a mates turbo civic which made only 130kw at the wheels, using a TD04, so it seems i am making significantly less then what i should (170atw for reference)
Does anyone have any information on the size of this turbo? Some people have said its a .48 ar, but it looks quite small. Ive been told these turbos support 180rwkw on the skyline engines, whether thats going to relate to my dohc vtec engine i doubt it, as it is different to your nissan engines.
The turbo does hold boost all the way to redline, which is 8200rpm, so there is no problem there.
Any information about the turbo would be great!
Regards,
Ben
https://www.sau.com.au/forums/topic/97938-stock-rb20det-turbo/
I dont want to cause a shiit here but, the lack of capacity has nothing to do with it.
On the 1.6 DOHC VTEC engine its well known that to achieve 170-180kw atw is attainable. That is however is most cases using a T3/T4 57trim .63ar turbo :)
Does anyone know the size of the nissan 16v-10?
I wouldn't go bigger turbo to achieve a 170kw power figure as you may be disappointed with the power delivery. You may get 170atw but in will be all or nothing.
As for yours not feeling quick I would get in on the dyno - check the timing, Air fuel ratios and boost levels.
There could be other things holding it back. I have a TD04L at home off a rex that I was going to turbo a corolla with. I think the RB20 turbo is a little bigger - not sure on specifics though.
Are you running standard internals? What engine management?
Any more than 130-140atwkw would be a waste. Ive been in a astra turbo that has 170kw (probably about 120-130atw) at the flywheel and any more in a front wheel drive would be silly.
You'll be fiighting wheelspin and torque steer
Edited by benl1981
Depending on the dyno the rb20t turbo's do make ~170rwkw with around 14psi, exhaust, fmic and tuned ecu on a RB20DET.
I've ran a rb20det turbo on my rb30det that runs the better flowing rb25 head, that requires only 9psi with the same above mods to make 176rwkw.
So... If the head isn't breathing well in a forced induction application then your going to have to push more boost in to it to bring the airflow up.
That turbo appears to be spooling well. On the RB20DET I used to see ~11psi by a shade over 3000rpm and 1bar by ~3500rpm under normal driving conditions. Load it up in 4th and 1bar would be seen at approx 2800rpm. I never saw boost at those rpms on the road as I would always drop it back a gear. :D
You haven't actually said how much yours is making?!?
Edited by Cubes
No need. Simply push more boost in to it.
RB25 turbo is only going to make it come on smoother and have less mid range.
Remember it is a little 1.6ltr, where it spools at the moment looks to be quite a nice streetable package that simply needs more boost. :blink:
Edited by Cubes
Remember it is a little 1.6ltr, where it spools at the moment looks to be quite a nice streetable package that simply needs more boost. :)
wouldnt it depend on if the engine is stock or not? Wouldnt it be safer to run a bigger turbo with less boost, than a smaller turbo with more boost.
I may be wrong, i am most of the time :blink:
-Michael :)
Thats always the case but it doesn't mean I'm going to run a GT42 as it may do 300rwkw on 10psi vs the GT30 running 20psi.
I know which will accelerate faster and be much nicer to drive due to a higher average power.
Which does raise another issue. Whats the static comp? This will influence the amount of boost he is able to run.
B16a's arent a little 1.6 litre.
you are forgetting that the high VTEC cam is some 290 degrees in duration - and you need a decent trubo to match this. A workshop in sydney that did turbo B16's used HKS 2835 turbos on their low and turbo kits, no lag, msooth power and made 230kw at the tyres...
Just somehting to think about.
Its his brother posting again here, his external wastegate opens at 10.7psi, so thats how much psi he is putting through the turbo - and your correct it is a t3 flange.
His current rb20det turbo is slowly dying, as the seals in it have just gone.
I will let him know MattSR your advice, though i think all he was really after was the 'specs' on the turbo.. as ozhonda, and more specifically an american honda website that specialises in turboing these engines has given him some ideas as to why he isnt hitting high powerfigures.
Keep the ideas and feedback comming, does anyone know the specific size of it .xx?
Dayne
Hi Cubes,
Totally agree there - I guess I was being a little over enthusiastic with my reply. It did have lag (as most engines with any decent turbo do) What I was trying to say was that the power delivery was really very linear, it slowly built boost from low RPM and was quite pleasant in its delivery.
Cheers,
Matt
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
