Hi Fellas
Im actually posting on my brothers account as I dont have one on the SAU forums :)
Im using an rb20det turbo (16v-10) on my Honda Civic VTiR, but it just isnt making any sort of decent power like it should. Basically on 10psi on my engine I should be ripping through the stock clutch and spinning tyres easily..
This is all based on a mates turbo civic which made only 130kw at the wheels, using a TD04, so it seems i am making significantly less then what i should (170atw for reference)
Does anyone have any information on the size of this turbo? Some people have said its a .48 ar, but it looks quite small. Ive been told these turbos support 180rwkw on the skyline engines, whether thats going to relate to my dohc vtec engine i doubt it, as it is different to your nissan engines.
The turbo does hold boost all the way to redline, which is 8200rpm, so there is no problem there.
Any information about the turbo would be great!
Regards,
Ben
https://www.sau.com.au/forums/topic/97938-stock-rb20det-turbo/
I dont want to cause a shiit here but, the lack of capacity has nothing to do with it.
On the 1.6 DOHC VTEC engine its well known that to achieve 170-180kw atw is attainable. That is however is most cases using a T3/T4 57trim .63ar turbo :)
Does anyone know the size of the nissan 16v-10?
I wouldn't go bigger turbo to achieve a 170kw power figure as you may be disappointed with the power delivery. You may get 170atw but in will be all or nothing.
As for yours not feeling quick I would get in on the dyno - check the timing, Air fuel ratios and boost levels.
There could be other things holding it back. I have a TD04L at home off a rex that I was going to turbo a corolla with. I think the RB20 turbo is a little bigger - not sure on specifics though.
Are you running standard internals? What engine management?
Any more than 130-140atwkw would be a waste. Ive been in a astra turbo that has 170kw (probably about 120-130atw) at the flywheel and any more in a front wheel drive would be silly.
You'll be fiighting wheelspin and torque steer
Edited by benl1981
Depending on the dyno the rb20t turbo's do make ~170rwkw with around 14psi, exhaust, fmic and tuned ecu on a RB20DET.
I've ran a rb20det turbo on my rb30det that runs the better flowing rb25 head, that requires only 9psi with the same above mods to make 176rwkw.
So... If the head isn't breathing well in a forced induction application then your going to have to push more boost in to it to bring the airflow up.
That turbo appears to be spooling well. On the RB20DET I used to see ~11psi by a shade over 3000rpm and 1bar by ~3500rpm under normal driving conditions. Load it up in 4th and 1bar would be seen at approx 2800rpm. I never saw boost at those rpms on the road as I would always drop it back a gear. :D
You haven't actually said how much yours is making?!?
Edited by Cubes
No need. Simply push more boost in to it.
RB25 turbo is only going to make it come on smoother and have less mid range.
Remember it is a little 1.6ltr, where it spools at the moment looks to be quite a nice streetable package that simply needs more boost. :blink:
Edited by Cubes
Remember it is a little 1.6ltr, where it spools at the moment looks to be quite a nice streetable package that simply needs more boost. :)
wouldnt it depend on if the engine is stock or not? Wouldnt it be safer to run a bigger turbo with less boost, than a smaller turbo with more boost.
I may be wrong, i am most of the time :blink:
-Michael :)
Thats always the case but it doesn't mean I'm going to run a GT42 as it may do 300rwkw on 10psi vs the GT30 running 20psi.
I know which will accelerate faster and be much nicer to drive due to a higher average power.
Which does raise another issue. Whats the static comp? This will influence the amount of boost he is able to run.
B16a's arent a little 1.6 litre.
you are forgetting that the high VTEC cam is some 290 degrees in duration - and you need a decent trubo to match this. A workshop in sydney that did turbo B16's used HKS 2835 turbos on their low and turbo kits, no lag, msooth power and made 230kw at the tyres...
Just somehting to think about.
Its his brother posting again here, his external wastegate opens at 10.7psi, so thats how much psi he is putting through the turbo - and your correct it is a t3 flange.
His current rb20det turbo is slowly dying, as the seals in it have just gone.
I will let him know MattSR your advice, though i think all he was really after was the 'specs' on the turbo.. as ozhonda, and more specifically an american honda website that specialises in turboing these engines has given him some ideas as to why he isnt hitting high powerfigures.
Keep the ideas and feedback comming, does anyone know the specific size of it .xx?
Dayne
Hi Cubes,
Totally agree there - I guess I was being a little over enthusiastic with my reply. It did have lag (as most engines with any decent turbo do) What I was trying to say was that the power delivery was really very linear, it slowly built boost from low RPM and was quite pleasant in its delivery.
Cheers,
Matt
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
