Hey peoples,
just thought I'd see how popular skylines are as a formal car thought we could get a tally going
I'll start so far i'm at five formals
be interesting to see how many we all end up doing as a whole
https://www.sau.com.au/forums/topic/97944-formals-how-are-the-lines-fairing/
it wasn't a burnout!!!!!! my foot just slipped of the clutch accidentally :D
but speaking of which you's know the yellow s15 that did an actual burnout ended up on the side of the road with the red and blues.
Also did any one hear about the gold supra at the convention centre that apparntly did the craziest burnout, yeah also ended up with the red and blues
Edited by Slither
have been hit up to do a couple.....but with no rear seat, its makes a good excuse to decline them
Ah,kids these days...too soft! Tell 'em to hang onto the rollcage! :lol:
it wasn't a burnout!!!!!! my foot just slipped of the clutch accidentally  :blink:
from what they are saying on canberra cruises, his throttle got stuck and he couldn't stop the car or sumthin.
then 5 mins after a commo got a panel dented cuz a rent a cop hit it cuz he was doing a burnout :lol:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
