Sorry if this sounds like a dumb question but I've been looking at buying a r32 and noticed that some seem to have the bonnet in place of the grill and the others have the GTR style grill (with the fins)
Can this gtr style grill be purchased and installed seperately or does it only come with certain models?
I much prefer this look on 32's so some answer to clarify this would be great as it would help me with my search
https://www.sau.com.au/forums/topic/97958-r32-gtst-front-grill-two-types/
from what i understand, theres two standard grills. GTS/GTSt/GTS4 grills is the one with the bonnet lip coming down. the fins style is the GTR.
GTR grills on nonGTR cars is a bit of a swapsies issue, where you need the bonnet, bonnet latch, grill, and grill mounts. the GTR grill screws onto these little mounts on the headlights. apparently the nonGTR cars headlights dont come with these mounts.
i dont know whether someone has made mounts for these grills for the headlights without, or you have to get the right headlights, or you can simply rig up your own mounts, but thats how it goes.
hope that helps,
shaun.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
