Hi all,
Anyone using one of Greddys alloy radiators on an R33 GTR? I have seen a few people using them and I would like to know if the factory fan shroud will fit with these or if the shroud becomes a throw away item.
Cheers,
Nick
I havent seen one fitted Nick but if i was to fit one i would definantly fit the shroud on .
Blitz - I have one on my car, the radiator shroud could not go back on, the brackets that the shroud bolts onto are not there, so I'm assuming it may be too thick and it would get too close to the engine if u were to put it back on.
With that said, I've had it on the car for over a year now and it has never overheated, the car is driven on the street and on the track aswell, on the street it sits on 84 degrees when cruising....
Hope that helps...
P.S I have a pic if ur interested to see how it will sit in the engine bay....
Hey Nick,
The shroud won't fit with the Greddy rad.
Interesting, that leads me to wonder which if any of the Japanese made radiators will allow for the refitting of the shroud?
I have a feeling that ARC allows for this
Hope that helps...
84 is not bad, and i know your car is in a much higher state of tune than mine, but with the oil cooler and standard rad my water temp always sits on about 80 degrees. do you have a big thick front mount?
My oil cooler sits behind the bumper on the passenger side behind the indicator (R33 GTR), I've also got an N1 water pump if that makes any difference.... City driving and idling in traffic it sits on 84, on the highway it drops down a couple of degrees....
Hi Nick, i got a Greedy radiator in mine and got the big girl running on the wkd woohoo would you like to post a pic or two, mine bolted straight in shroud and all. Its truely a beautiful piece of gear.
i also got nismo low temp thermostat and 8.5 to 9litre oil capiacty without the oil cooler fitted yet and run temps in cool weather seem quiet low at moment but only dont like 40kms (68 to 72deg)
Jagr33 you got your new turbos in yet and if so how did they shape up.
pete
Edited by pnblight
yeah, i guess the n1 pump may make a little difference. damn they are a nice looking radiator :(
Hey Pete,
Yeah picked it up a week ago, new turbo setup is sweeeet!!! So much more response down low and midrange compared to T517Z's, but do lack the top end....
Sending you PM now....
BACK ON TOPIC!!! :D
  • 4 months later...
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
