I have an air leak at the rear of the plenum. Hard to say at this stage where exactly it is but it is definately audible using a little piece of tube shoved down there. At this stage I am thinking one of the gaskets on the rear throttle body or intake manifold has blown out. Anyway seeing as I have some time off over Xmas I was going to tackle this problem myself, I have the trusty R32 GTR workshop manual here and although on paper it doesn't look that difficult upon serious inspection I am a bit bothered by the lack of access to some of the bolts. Might just bite the bullet and pay someone to do it, I just got scared off by the "allow at least 10-12hrs labour" quote.
Has any one here performed this task? If so is there anything I should look out for, any problems you encountered?
Thanks in advance
Jason
https://www.sau.com.au/forums/topic/97986-gtr-plenum-removal/
bolts on bottom of plenum are a absolute bitch to get to
but 10-12 hrs DAMN i think that guy just wants some money out of you
my mechanic with the help of the manual had it off in under 3 hrs
but he was swearing and cursing about the lack of access
if you got the tools and patience and a spare weekend i dont see why you couldnt do it yourself
only reason i got my mechanic to do it is i knew it would be a headache and i didnt want a headache
as for problems didnt run into any other than u need a trained monkey to climb in engine bay for you
Good Luck
RellikZephyr
Sounds like I am in for some "fun" then. . . . . I am tempted just to get the mechanic to do it to save the headache too, but it would probably be more rewarding if I did it myself, and I would much prefer to spend those dollars on a pfc.
Its the bolts under the plenum which are really bothering me. I figure if they are hard to take off they will be even harder to put back on. The oil filter relocation kit isn't helping either. . . . .
Thanks in advance
Jason
I would be tempted to lift the engine to do it.
nah its a ball ache alright ....but i wouldnt knock back the job of doing it myself......just make sure you got 1/4 drive flexible sockets....not a uni joint but the flex head sockets themselves.......and take your oil filter off first otherwise the bolt that holds on the vacumm chamber thingy underneath fall down and bang on the oil fiter
Thanks in advance
Jason
mine has the same problem no4 cylinder droped out let me no if u found any probs
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
